Author Topic: Having issue with inheritance, can not find solution anywhere.  (Read 4999 times)
Offline Runelixx
« on: September 24, 2019, 12:54:28 am »
ULib v2.63d
ULX v3.73d
Game mode(s) I am having this problem on: Custom DarkRP
I am attempting to create a role with not many permissions but some custom commands and they should be lower than admin and all the ranks above, just inheriting from base user, however when I inherit from user it sets them above the rest up to superadmin and those above that. Should I set admin to inherit from the rank below it or will that cause issues?
Re: Having issue with inheritance, can not find solution anywhere.
« Reply #1 on: September 26, 2019, 08:29:12 pm »
Could you run ulx debuginfo from your server console and attach the file it generates here?
This will allow us to look at your group structure and find where the problem is. Thanks! :)
