Author Topic: Help me. I needed a function for checking mut?  (Read 6939 times)
Offline Aimatt
« on: October 04, 2019, 03:14:45 am »
Hello! Here I decided to make a short admin menu made functions, but I need to make a button with mute and gag at the same position, for this I need to do:
if <the check function> then
     mute
     unmute
In the likeness of this.
Offline Timmy
  • Code monkey
Re: Help me. I needed a function for checking mut?
« Reply #1 on: October 04, 2019, 05:47:32 am »
Assuming you use ULX to perform the muting/gagging.
ULX sets a networked boolean (NWBool) when a player is muted or gagged. You can use this to test if the restriction is active.
  1. if ply:GetNWBool("ulx_muted") then
  2.   -- ply is muted
  3. else
  4.   -- ply not muted
  5. end
  1. if ply:GetNWBool("ulx_gagged") then
  2.   -- ply is gagged
  3. else
  4.   -- ply not gagged
  5. end
