Author Topic: Addon like utime but not utime  (Read 89360 times)
Offline BmanGames
« on: October 29, 2019, 12:30:00 pm »
The utime code is crap and outdated and makes people crash with a lua panic error so any addons like it that works?
Re: Addon like utime but not utime
« Reply #1 on: October 29, 2019, 12:48:06 pm »
I've used UTime for the past several years and have never had anyone crash. The code is also not "crap and outdated" (although I agree some things like using UniqueID should be changed).
I HIGHLY doubt that UTime uses enough memory to cause a Lua panic error (error occurs when client runs out of memory) because, actually looking at the code, all variables are networked between client and server and the UI is just drawn on the screen.
If people are crashing with a Lua panic error, I'm confident that another add-on is the cause.
Offline BmanGames
« Reply #2 on: October 29, 2019, 01:40:19 pm »
Not sure all ik is ive seen people with the same problem and when i removed it people stop timing out
Offline BIOMAN
« Reply #3 on: July 28, 2023, 08:59:38 pm »
honestly havent had a problem with work as it was built, you must have a conflicting script.
