Author Topic: Disable !menu  (Read 6189 times)
Offline Ryu
Disable !menu
« on: April 23, 2020, 11:15:20 pm »
Hello, I am trying to see if there is a way to disable the ULX Menu while still being able to use the MOTD function of it for a Gmod DarkRP server. The issue being I have an alternate admin mod, and ULX opening it's menu when I try to use my admins mods menu is kind of a pain and a completely redundant side effect of running the two together. So I'm hoping there is a way to simply remove the pop up of the admin menu or maybe limit it to only pop up for myself (so I can configure things my admin mod may not have options for). Or maybe even change the command used to open the ULX menu to something only I would know so that when my admins are opening their menus they are not accidentally opening the ULX one. Several ideas and hopefully maybe a solution for at least one of them.
Offline Ryu
Re: Disable !menu
« Reply #1 on: April 23, 2020, 11:25:45 pm »
Might I add also, if there is a way to disable EVERYTHING except the MOTD I will take that option as well.
Re: Disable !menu
« Reply #2 on: April 25, 2020, 12:46:46 am »
It's just permissions.
Revoke permission to things you don't want people to use.
To revoke the menu.. revoke the 'ulx menu' permission from all groups except superadmin or whatever group you are.
Same with all other commands you don't want people to have access to.
