Author Topic: help script  (Read 7874 times)
Offline $VDFOREVER
help script
« on: June 11, 2020, 02:52:12 pm »
Hello, I have a script for showing time in jail, but I have a mistake. Help fix it.
  1. hook.Add("HUDPaint", "JailTime", function()
  2.         if LocalPlayer():isArrested() then
  3.                 draw.RoundedBox(8, 8, 10, 570, 35, Color(30, 30, 30))
  4.                 draw.SimpleText("Before leaving prison "..math.floor(LocalPlayer():GetArrestInfo().Release - CurTime()).." seconds.","HudFontBold", 10, 10, Color(80, 80, 80))
  5.         end
  6. end)
  7.
[ERROR] lua/autorun/client/cl_jail.lua:5: attempt to call method 'GetArrestInfo' (a nil value)
  1. fn - lua/autorun/client/cl_jail.lua:5
   2. unknown - addons/ulx_ulib/lua/ulib/shared/hook.lua:109
« Last Edit: June 11, 2020, 03:14:05 pm by $VDFOREVER »
Re: help script
« Reply #1 on: June 11, 2020, 06:16:55 pm »
Method is nil. Empty.
Hud is client side.
Is that funtion server side?
Also, moving to developer corner, you posted in section for team Ulysses project support.
Re: help script
« Reply #2 on: June 12, 2020, 01:38:26 pm »
Looking at the DarkRP wiki (which I assume this is for), that function doesn't exist anywhere. You could define the function, and use other functions to populate the data it would return, for example, use the SERVERSIDE playerArrested hook to populate a shared table on the player object containing said information.
