Author Topic: Superadmin having No Powers  (Read 7711 times)
Offline Milner
« on: September 05, 2020, 01:09:19 pm »
So ULX has been fine for ages until I clearly <censor> something up and now Superadmin is powerless. I tried groupallow and giving it all its powers back but I was unsuccessful. Do you know how I can give Superadmin all it's powers back?
Little FYI Its Sanbox
« Last Edit: September 05, 2020, 01:40:21 pm by Milner »
Re: Superadmin having No Powers
« Reply #1 on: September 05, 2020, 05:54:53 pm »
You can try resetting ULX to defaults. This will require some work on your end depending on how much setup you've done for permissions, but might be the easiest way if you've royally screwed up something.
To do this, run
ulx resettodefaults
run that from your server's console.
