Author Topic: sui_scoreboard - Sandbox Replacement Scoreboard REMIXED  (Read 174897 times)
Offline Sylar
Re: sui_scoreboard - Sandbox Replacement Scoreboard REMIXED
« Reply #75 on: September 28, 2008, 05:16:29 am »
ofcourse not, but the message what rating means not appearing when the cursor is hovering on them
Offline Meatloaf
« Reply #76 on: January 25, 2009, 08:43:21 pm »
Is there a way to rate people via console? if so can you post the command, I want people to be forced give me a gold star rating every time they they spawn one of the expression 2 chips that I've made :D
Offline Dark_Hero
« Reply #77 on: March 21, 2009, 05:16:27 pm »
I get this error on console when i press TAB
ERROR: GAMEMODE:'ScoreboardShow' Failed: autorun/sui_scoreboard.lua:44: attempt to index global 'SuiScoreBoard' (a nil value)
ERROR: GAMEMODE:'ScoreboardHide' Failed: autorun/sui_scoreboard.lua:56: attempt to index global 'SuiScoreBoard' (a nil value)
I got the same error when i tried the modified_sui_scoreboard to.
I have ULX/Ulib and Uteam installed and they all work fine.
« Reply #78 on: March 22, 2009, 10:59:44 am »
Do you have sv_downloadurl set up correctly?
Offline Dark_Hero
« Reply #79 on: March 23, 2009, 11:03:53 am »
Yes its set up correctly. Or do i need to add sui_scoreboard to my fastdl server to?
« Reply #80 on: March 23, 2009, 11:06:44 am »
You need to add the cache files to the server, yes.
Offline Dark_Hero
« Reply #81 on: March 23, 2009, 11:54:27 am »
Just another question  ::) . I just upload the dua folder to my fastdl server? Or should there be sui_scoreboard files in the cache folder? Because if they should then i dont see them .
I just see gmod/cache/dua thats all
EDIT: I got the scoreboard working by uploading the cache to the fastdl server like you told me. It looks great keep up the good work ;)
:luaking:
« Last Edit: March 23, 2009, 01:39:53 pm by Dark_Hero »
Offline SpawnZlive
« Reply #82 on: March 30, 2009, 05:37:32 pm »
I'm having a problem with it on my server.
Whenever you press tab for the scoreboard, it pops up but doesn't show any text and if you release tab it stays on your screen.
Here's console error.
Warning: vgui.Create failed to create the VGUI component (SuiScorePlayerRow)
vgui.Create: Error when calling 'SuiScoreBoard':Init (sui_scoreboard/scoreboard.lua:73: attempt to index local 'button' (a nil value))
sui_scoreboard/scoreboard.lua:234: attempt to index field 'lblPing' (a nil value)
sui_scoreboard/scoreboard.lua:194: attempt to index field 'lblPing' (a nil value)
How can I fix this?
-Edit
Just found out this is clientside, the funny thing is I don't have the mod installed in my gmod folder. I'll trying deleting my cache folder
« Last Edit: March 30, 2009, 06:09:29 pm by SpawnZlive »
« Reply #83 on: September 14, 2011, 02:14:49 pm »
Where does this save the rating file? Also is it possible for me to remove the ability of people rating other people "gay". (or just remove ratings all together.)
« Reply #84 on: September 14, 2011, 02:24:22 pm »
I believe it's in your sv.db and I do believe ratings could be disabled all together with some editing.
