Author Topic: !strip <player>  (Read 20761 times)
!strip <player>
« on: August 11, 2007, 08:50:10 pm »
There have been plenty of times when simply stripping the weapons from an abusive player might solve some issues or whatever. I noticed how COnna had included a command to strip a player of all their weapons including their tool gun with SAT and I was wondering if this could be added to ULX. I think it is a needed addition to the best admin mod out there.
Please consider it.
Offline Chironex
  • Formerly known as Kyzer
Re: !strip <player>
« Reply #1 on: August 11, 2007, 09:36:42 pm »
Here is the command, put that in ulx/lua/ulx/fun.lua
function ulx.cc_stripweapons( ply, command, argv, args )
if #argv < 1 then
ULib.tsay( ply, ulx.LOW_ARGS )
return
local targets, err = ULib.getUsers( argv[ 1 ], _, true, ply ) -- Enable keywords
if not targets then
ULib.tsay( ply, err )
return
for _, v in ipairs( targets ) do
ulx.logUserAct( ply, v, "#A stripped #T's weapons" )
v:StripWeapons()
ulx.concommand( "strip", ulx.cc_stripweapons, "<user(s)> - Strips user(s)'s weapons.", ULib.ACCESS_ADMIN, "!strip", _, ulx.ID_PLAYER_HELP )
Re: !strip <player>
« Reply #2 on: August 11, 2007, 09:55:42 pm »
Heh, don't you love how easy it is to add stuff to ULX? :D That whole code block was template except for one line.
Maybe we should work on making it even more module and robust. :)
Offline Chironex
Re: !strip <player>
« Reply #3 on: August 11, 2007, 10:06:48 pm »
Yes it's very easy to add things, for those who have a minimum of knowledge :)
Re: !strip <player>
« Reply #4 on: August 12, 2007, 12:09:34 am »
Thankyou very much for your help guys.. I appreciate it a lot.
Offline Golden-Death
  • Honored Lua Scripter
    • BlueFire
Re: !strip <player>
« Reply #5 on: August 12, 2007, 12:17:08 am »
All you people take mah old plugin ideas and stick em in ULX. /shakefist
Re: !strip <player>
« Reply #6 on: August 12, 2007, 07:07:43 am »
I believe this is bad practice. Any changes you make would get overwritten during an update by us.
Meg, perhaps we should make a 'modules' folder for ULX?
ULib has a modules folder that will load code placed there after ULib loads...but there is no quick easy place to put functions/code that will load after ULX. I could see someone placing a bit of code there that should work with ULX, and it try to load first before ULX is loaded.
Re: !strip <player>
« Reply #7 on: August 12, 2007, 07:10:03 am »
:P
We didn't include it in ULX.
Another member like yourself made a contribution. :D
    • BlueFire
Re: !strip <player>
« Reply #8 on: August 12, 2007, 12:19:02 pm »
:P
This time.
Re: !strip <player>
« Reply #9 on: August 12, 2007, 12:27:49 pm »
And now ULX is modularized! :D
Check out SVN if you wanna see it.
Offline Chironex
Re: !strip <player>
« Reply #10 on: August 12, 2007, 01:25:38 pm »
Hmm, what that mean exactly ?
Another question related to :
Can i create a new file and place my commands in it (without bugs like commands not showing in ulx help), so this is not deleted when there is a svn update ?
Re: !strip <player>
« Reply #11 on: August 12, 2007, 01:29:10 pm »
With the new module system, you can just stick your commands in a separate file under the 'module' folder.
Offline Chironex
Re: !strip <player>
« Reply #12 on: August 12, 2007, 02:04:22 pm »
Ok, tested, works :)
Also i saw you did so commands are sorted alphabetically (ulx help), thanks.
But (sorry wrong place):
ULX version 3.20 (BETA) SVN revision 40 loaded.
Timer Error: base.lua:166: bad argument #1 to 'ipairs' (table expected, got nil)
Re: !strip <player>
« Reply #13 on: August 12, 2007, 07:06:55 pm »
Hmm interesting. Either the ULX callback isn't working or something's seriously screwed up. Was this error on a listen server? Do you get it each time?
Offline jrarmas
Re: !strip <player>
« Reply #14 on: September 27, 2013, 11:02:01 pm »
I have an issue when i insert the like
" function ulx.cc_stripweapons( ply, command, argv, args )
   if #argv < 1 then
      return
   if not targets then
      return
      v:StripWeapons()
ulx.concommand( "strip", ulx.cc_stripweapons, "<user(s)> - Strips user(s)'s weapons.", ULib.ACCESS_ADMIN, "!strip", _, ulx.ID_PLAYER_HELP )"
i load up my server and it boots me (to main menu) saying "Too many lua errors"
PLEASE HELP!
