Author Topic: Prevent Entities Being Spawned and moved into spawn?  (Read 8248 times)
Offline Kingtendo
« on: August 18, 2007, 11:41:28 am »
To put it simply, is there any way you could prevent entities being spawned and moved into spawn by finding all info_player_start 's and creating a box around them of any size. so when entities and spawned inside this box, or moved into this box, the entity get's removed.
Thanks
Offline Chironex
  • Formerly known as Kyzer
Re: Prevent Entities Being Spawned and moved into spawn?
« Reply #1 on: August 18, 2007, 11:59:28 am »
Good idea, i think it's possible, i'll see if i can do that as another ulx module :p
Offline Kingtendo
« Reply #2 on: August 18, 2007, 12:05:04 pm »
Thanks for the quick response, it isn't actually my idea though.
Offline Golden-Death
  • Honored Lua Scripter
    • BlueFire
« Reply #3 on: August 18, 2007, 05:20:47 pm »
Could cause problems if a player drives his contraption into the spawn area.
Offline Chironex
« Reply #4 on: August 18, 2007, 11:11:29 pm »
Maybe applying a force to make it go away )
« Reply #5 on: August 19, 2007, 12:30:59 am »
On top of a 'force field' or 'pusher field', also use a timer.
If someone drives into the area, it doesn't move them until 5 or 10 seconds has passed.
Give a warning to player in spawn area warning of such, etc.
