Author Topic: physgun  (Read 8019 times)
Glitch
physgun
« on: August 18, 2007, 01:21:37 pm »
how do i make it so players can't pick each other up with the physgun
thanks
Offline Chironex
  • Formerly known as Kyzer
Re: physgun
« Reply #1 on: August 18, 2007, 01:29:13 pm »
There is a easy example on the wiki:
http://www.garrysmod.com/wiki/?title=Gamemode.PhysgunPickup
If you need you can add an admin check so only admins can pickup players
Re: physgun
« Reply #2 on: August 18, 2007, 04:51:55 pm »
Kyzer, he's probably thinking the ULX feature.
Remember, most who come here don't know Lua. (And of those that don't, even fewer want or care to learn)
Glitch,
ULX only allows admins to pick players up.
99% of the time a player can pick another player up, its not ULX's fault, but a conflicting mod.
In the past, several other prop protect scripts broke the feature.
Also, make sure ou have ULX 3.11
Glitch
Re: physgun
« Reply #3 on: August 20, 2007, 03:58:23 pm »
well I've been interested in LUA but i don't want to learn right now and I have the svn version 3.20 but all players can still pick each other up. and i know I am the only admin i even tested it with other players. I' don't know if it makes a difference that it is a lan server
Glitch
Re: physgun
« Reply #4 on: August 20, 2007, 04:00:20 pm »
and i don't have any prop protection or even anything remotely similar
Re: physgun
« Reply #5 on: August 20, 2007, 05:20:28 pm »
Remove all other mods but ULX and ULib and let us know if you're still having trouble.
Glitch
Re: physgun
« Reply #6 on: August 20, 2007, 08:43:51 pm »
i guess it is a conflicting addon the painful part will to find ouot which
thanks for the help
Offline spbogie
Re: physgun
« Reply #7 on: August 20, 2007, 08:51:49 pm »
When you figure out, please post back with the results.
Glitch
Re: physgun
« Reply #8 on: August 20, 2007, 09:59:14 pm »
turned out to be the latest svn of GCombat recently tiberium was added and the tiberium tower was messing it up i saw someone mention. so i dongraded to version 11 and that fixed it.
thanks again for the help
Re: physgun
« Reply #9 on: August 20, 2007, 10:08:00 pm »
Thanks for the info Glitch. Letting us know what breaks our stuff is helpful.
We may not always be able to fix it or make a work around, but we can at the least let others know if ever asked.
