Author Topic: physics gun / use key  (Read 12052 times)
Offline Rich
« on: August 27, 2007, 10:19:18 pm »
hi guys
Could do with a little help.
I have setup a dedicated server witch is all working find but one thing
The physics gun will not rotate anything when i hold the use key also i setup a rp gamemode on this server and i can not open or close doors the use key again.
I know its not my settings, and it works on anyother server i go on.
I cant find anything in the files that might allow me to fix this anyone got any ideas
Pls help
Thanks
Rich
Re: physics gun / use key
« Reply #1 on: August 28, 2007, 01:12:25 pm »
One of your addons is overriding the use key.
Offline Rich
« Reply #2 on: August 28, 2007, 02:21:03 pm »
Right
No its not that
I have install a new server with no addons or added anything to it
The physics gun will not rotate anything from the start
Now we also tested it on 2 servers we have and its the same
Thank for helping anyway mate
Offline Chironex
  • Formerly known as Kyzer
« Reply #3 on: August 28, 2007, 02:38:19 pm »
What with the default Sandbox ?
Try a VERY fresh installation (no modifications at all), and it still don't work then i really don't see :/
« Last Edit: August 28, 2007, 03:38:40 pm by Kyzer »
Offline Rich
« Reply #4 on: August 28, 2007, 03:26:26 pm »
Thats what i did no modifictions at all
and thats what i am thinking i dont get it at all
But i know this i host servers and i have rented 2 out and they have the same thing so i was thinking its the server its runing on but i have 2 and there diff server could it be the server files that i am using maybe hmm
Offline Chironex
« Reply #5 on: August 28, 2007, 03:38:20 pm »
Lol you copied my spelling mistake :)
Well i don't know..be sure to download latest server files from hlds
« Reply #6 on: August 28, 2007, 05:49:31 pm »
Rich, you say this happens on two or three different servers you have set up.
It doesn't do it on others you have not set up?
Does it happen to anyone else besides you on any server you had problem on?
Offline Rich
« Reply #7 on: August 28, 2007, 10:11:16 pm »
No it seen to be on servers i host
other server i go on it works find
Its got to be the file
« Reply #8 on: August 29, 2007, 04:31:37 am »
What file?
Delete your garrysmod server.
Re-install Garry's mod server.
Re-install Garry's mod game/client.
Don't add any addons.
Join your server.
Try it. If it's broken..it is something beyond our control.
Add ONLY ULib and ULX, using ULX 3.11, to your server.
Try joining again. If it does it, see if there are errors in console of server when you try it.
Add ONE addon at a time. Check for errors each time.
Rich, you are the only person to report this problem. It's something on your end..we're not sure what.
Offline Rich
« Reply #9 on: August 29, 2007, 07:35:02 am »
Well i like to thank you all for helping so far as you no it is making me pull my hair out
Anyway that did not work.
when the server is all setup with ULib and ULX and if i add anything to it
it all works with no errors
Just the physics gun will not rotate i do not get it.
Here the bad new i got garry him seft to look at it and he does not no whats going on
to him its setup all right.
Now i am not giving up at all on this
I got it down to one thing The files that run on my dedicated server
Now the files are setup on the server so when someone buys a server for gmod they install the same files and they have had the same rotate thing going on in there server
So maybe i have not got the right ones or my one is messing some thing
So can anyone get me a link for gmod 10 dedicated server files maybe one that you have used so i know it works and are there diff ones i am sure i have seen a v9.00 and a 9.04
But not sure
Thanks Rich
Offline Chironex
« Reply #10 on: August 29, 2007, 10:17:31 am »
When you download from hlds it is be the latest server files,
http://www.garrysmod.com/wiki/?title=Dedicated_Server_Setup
Offline Rich
« Reply #11 on: August 29, 2007, 11:22:08 am »
Yep when with it 2 times got it right gun still the same
Going to be sad and cri all night
Offline Chironex
« Reply #12 on: August 29, 2007, 11:44:16 am »
Weird, sorry i can't help you more :/
Offline Rich
« Reply #13 on: August 29, 2007, 01:02:02 pm »
WOOOOOOOOOOOOOOT I did it it was the server files replaces the lot one by one so i new it was right.
Anyway thanks for all your help guys.
Keep a look out for my new rp server
warservers.com
Thanks
Rich
