Author Topic: Superman command.  (Read 10364 times)
GranPC
Superman command.
« on: September 03, 2007, 02:40:42 pm »
Hey people! I've been using ULX for some time and it's great. I wondered if there would be a way to get the Superman addon and the ragdoll command to make a superman command. To find superman, use www.garrysmod.org. Using non-svn release.
Thanks.
Offline Chironex
  • Formerly known as Kyzer
Re: Superman command.
« Reply #1 on: September 03, 2007, 02:53:11 pm »
You could use my Ghost script (original by Spacetech) but the ragdoll will be moved by his torso lol. A solution is to statue it (in a superman position :P) and..with little tricks, there is way to fly like superman :)
GranPC
« Reply #2 on: September 03, 2007, 02:55:14 pm »
Erm... Never seen the Superman addon? It allows you to move the ragdoll.... >_>
Offline Chironex
« Reply #3 on: September 03, 2007, 03:12:22 pm »
Ah. Sorry then. It's just i don't see the difference, as i said the ghost script still allow to drive ragdolls :-*
« Reply #4 on: September 03, 2007, 07:14:05 pm »
Superman (at least last time I looked), only allowed for 'flying', and viewing of the body flying, on the client side only.
No one else on the server could see you.
Seems a bit complicated for the likes of ULX as an admin mod.
Perhaps a access based module for ULib, but not necessarily ULX.
GranPC
« Reply #5 on: September 04, 2007, 01:32:03 am »
It is possible. I never thought bring was possible, for an example, but it is easier than I thought. We could try to combine the ragdoll command with the superman, editing a bit the superman one so that instead of moving the dead guy's grave it moves the ragdoll we created.
« Reply #6 on: September 04, 2007, 05:39:16 am »
This definitely is not something you're going to see in the default ULX. Why? We try to only put commands in ULX that are going to be truly useful to admin your server.
GranPC
« Reply #7 on: September 04, 2007, 11:17:54 am »
For an example. Does that tell something? I DON'T WANT IT IN THE DEFAULT ULX, I WANT IT IN *MY* ULX... Sorry dude, but that's been requested and my only idea was: ULX.
« Reply #8 on: September 04, 2007, 05:52:13 pm »
As I said.
Have fun finding someone to do it for you.
GranPC
« Reply #9 on: September 06, 2007, 01:25:22 am »
Umm... That's not really easy to do. I tried to do it by myself, but as I never coded in lua, I messed up the ULX command. The second time, if I applied the command to somebody, he would be ragdollized and couldn't come, apart from when I unsupermaned them, they couldn't use ANY tool or even worse, spawn stuff.
« Last Edit: September 06, 2007, 03:40:59 pm by JamminR »
