Author Topic: Send Menu v1.1  (Read 41750 times)
Send Menu v1.1
« on: February 16, 2006, 08:21:30 am »
Requirements:
ULX v1.1
Download:
http://ulyssesmod.net/sendmenu-v1_1.zip
Version: 1.1
This plugin will make clients "download" the server menu for as long as their connected to your server. For example, if you have custom props on your server, you'd want to make a menu for those props so clients would know about them and would be able to use them. Also includes an option to erase the client's current menu and only use the menu the server sends them.
INSTRUCTIONS:
Download the zip and extract the .lua file to your ULX modules folder.
Send Menu uses the following variables:
ulx_sv_sendmenuenabled - If enabled, clients will be sent the menus from the server
ulx_sv_sendmenuclearold - If enabled with sendmenuenabled, the client's original menu will be cleared
ulx_sv_sendmenudir - Where sendmenu will take it's menus from, USE '/' AND LEAVE OFF THE TRAILING '/'
These variables both default to enabled. To change them, add the configuration you want to your ULX server.ini. For example, if you don't want it to clear the client's current menu, just add "ulx_sv_sendmenuclearold 0" to your server.ini
Hope you enjoy it!
Changelog:
v1.1 5/22/06
* Fixed overflow problems ( Timer delays menus, you can change the delay with the increment variable )
v1 02/22/06
* ulx_sv_sendmenuclearold now defaults to off
* Fixed cvar checks
* Added ulx_sv_sendmenudir
* Added some ULX checks
v0.9 02/16/06
* Initial release
Thanks to:
TheDarkFactor for helping me track and kill the overflow problem as efficiently as possible.
« Last Edit: May 22, 2006, 06:55:09 pm by Megiddo »
Dan
Re: Send Menu 0.9
« Reply #1 on: February 21, 2006, 02:25:54 pm »
your comp is sick, maby to much porn? lol
nice mod tho
Re: Send Menu 0.9
« Reply #2 on: February 21, 2006, 02:50:47 pm »
nice mod tho
Actually, it was because my hard drive wasn't running on DMA for some reason. I took it out to test it on another computer and one of the pins fell out of the solder joint. I spent 2 hours soldering the pin back on, and eventually fixed the DMA problem by switching the hard drive channel with the cdrom drive channel. Next time you want to make a rude comment, keep it to yourself.
Re: Send Menu 0.9
« Reply #3 on: February 22, 2006, 08:22:09 pm »
Up to version 1.0, read above changelog for more information
Offline piggy
Re: Send Menu 1.0
« Reply #4 on: February 23, 2006, 09:24:25 am »
erm i put that mod in the modules folder like u said and its not letting nay one on the server it keep saying this (from console)"Disconnect: Client 1 overflowed reliable channel.." what does this mean lol  ???
Re: Send Menu 1.0
« Reply #5 on: February 23, 2006, 10:21:24 am »
It means you should ditch the dial up
Offline piggy
Re: Send Menu 1.0
« Reply #6 on: February 23, 2006, 10:56:18 am »
Im not on dial up!
And its not just me it happens to every one who tries to join the server gets it
Re: Send Menu 1.0
« Reply #7 on: February 23, 2006, 11:34:31 am »
Im not on dial up!
What directory are you sending and how many files are in it? ( List the contents of the directory )
Offline jesus
Re: Send Menu 1.0
« Reply #8 on: February 25, 2006, 04:14:11 pm »
Does this mod mod mod allow you to send any file to the client?
If so = Bad.
Re: Send Menu 1.0
« Reply #9 on: February 25, 2006, 05:24:35 pm »
No. I wish you'd read what I wrote above.
Diggl
Re: Send Menu 1.0
« Reply #10 on: April 01, 2006, 12:25:46 am »
Looks good.. But. uh what can it be used for?
Offline Golden-Death
  • Honored Lua Scripter
    • BlueFire
Re: Send Menu 1.0
« Reply #11 on: April 01, 2006, 10:35:48 am »
If your server builds forts a lot, you can make a menu called "X's Server - Fort Building'
and put all the props you use for fort building inside.
Re: Send Menu 1.0
« Reply #12 on: April 01, 2006, 04:27:07 pm »
Or custom models, or just a reorganized menu, etc.
Offline deathsol
Re: Send Menu 1.0
« Reply #13 on: May 17, 2006, 11:37:19 am »
Is it just me or does this not work with the latest version of ulx?
Re: Send Menu 1.0
« Reply #14 on: May 17, 2006, 06:52:29 pm »
It works fine. If you're trying to see the affect from a listen server, you obviously won't see any changes.
