Author Topic: Cvar Addon Module 0.2  (Read 14994 times)
Offline Chironex
  • Formerly known as Kyzer
« on: October 04, 2007, 02:22:40 am »
THIS IS FOR ULX 3.2x
This small module (smallest ever :)) allow you to add buttons and sliders into the Admin menu, from your configuration files (server/gamemodes/maps configs).
Here is some examples:
ulx addCvarSlider <slider label> <console variable> <slider max value> <optional: deny overflow>
ulx addCvarSlider "Max Wire Thrusters:" "sbox_maxwire_thrusters" 20
ulx addCvarSlider "Max Wire Values:" "sbox_maxwire_values" 100 1
ulx addCvarButton <label when disabled> <label when enabled> <console variable>
ulx addCvarButton "Enable CDS" "Disable CDS" "CDS_Enabled"
Changelog:
v0.2: the only problem found has been fixed
Report bugs/suggestions/anything, thanks.
Place this file into "addons/ulx/lua/ulx/modules" :
« Last Edit: October 04, 2007, 12:19:44 pm by Kyzer »
Re: Cvar Addon Module
« Reply #1 on: October 04, 2007, 09:30:11 am »
this is pure win.. thank you. ;D ;D ;D
Offline Chironex
« Reply #2 on: October 04, 2007, 10:03:02 am »
« Reply #3 on: October 04, 2007, 10:42:14 am »
Good job! :D
Offline Chironex
« Reply #4 on: October 04, 2007, 12:17:54 pm »
Thanks lol,
I made a small update, now it sets the cvar to the limit you specify, if the cvar current value is greater than your limit...i don't know if you understand what i've just said, so here is an example:
Say you have this cvar: "sbox_maxwire_shits" with a default value: 50
In the old version of this script, if you do:  ulx addCvarSlider "Wire Shits:" "sbox_maxwire_shits" 10 , this will create a slider with max value 10, but the current value of this cvar is still 50 until you click Apply.
Well, now this problem is fixed, redownload from first post :)
