Author Topic: UTeam  (Read 4823 times)
Monkey Poop.
UTeam
« on: October 07, 2007, 01:40:30 pm »
When I use Uteam superadmin and admin show in the menu but when i add someone to senior or any other team it shows client.
Heres my Uteamt.txt
"Out"
   "teams"
      "1"
         "name"      "SuperAdmins"
         "group"      "superadmin"
         "armor"      "1000"
         "hp"      "1000"
         "color"
            "a"      "255"
            "B"      "85"
            "g"      "200"
            "r"      "0"
                        "model"          "super"
      "2"
         "name"      "Admins"
         "group"      "admin"
         "armor"      "500"
         "hp"      "500"
         "color"
            "a"      "255"
            "B"      "50"
            "g"      "50"
            "r"      "255"
                        "model"        "combine"
      "3"
         "name"      "Moderator"
         "group"      "moderator"
         "armor"         "300"
                        "hp"            "300"
                        "color"
            "a"      "255"
            "B"      "255"
            "g"      "100"
            "r"      "0"
                        "model"         "police"
      "4"
         "name"      "Senior"
         "group"      "Senior"
         "armor"      "250"
         "hp"      "250"
         "color"
            "a"      "255"
            "B"      "44"
            "g"      "211"
            "r"      "255"
                        "model"         "prison"
                "5"
         "name"      "Regular"
         "group"      "Regular"
         "armor"      "200"
         "hp"      "200"
         "color"
            "a"      "255"
            "B"      "44"
            "g"      "200"
            "r"      "255"
                        "model"
                "6"
         "name"      "Client"
         "group"      "user"
         "armor"      "100"
         "hp"      "100"
         "color"
            "a"      "255"
            "B"      "60"
            "g"      "211"
            "r"      "255"
                        "model"          "male1"
   "gamemodes"
      "1"      "Sandbox"
      "2"      "SpaceBuild"
Re: UTeam
« Reply #1 on: October 07, 2007, 01:47:46 pm »
Use the command "ulx debuginfo" in the SERVER console while you have some of your senior members connected and paste the output here.
Re: UTeam
« Reply #2 on: October 07, 2007, 01:55:16 pm »
ULib and UTeam lua groups are case sensitive.
I notice you have 'Senior' as the group in your UTeam text posted.
You can capitalize the 'Name' in Uteam, but I'm betting "group" "Senior" should be lower case S. "senior" not "Senior"
Re: UTeam
« Reply #3 on: October 07, 2007, 04:56:23 pm »
I knew exactly what your problem was before I finished reading the replies.. and JamminR is correct. I usually make the Name of the group Capitalized and the group simple and lower case.. so like..
"name"     "Senior Member"
"group"     "member"
and when you go to add someone to the group, you want to use the group field data.. so... 'ulx adduser Megiddo senior'
also... If you are using Spacebuild2 make sure you put that in the game modes thing at the bottom of the file.. Spacebuild2 is NOT Spacebuild and this addon will not know the difference.
