Author Topic: ULX help  (Read 5660 times)
Metalgear
ULX help
« on: October 13, 2007, 11:13:02 am »
right well this is the first server i have ever got so im new to it all
any way i was recommended ULX admin mod for my server i downloaded and put it in the servers addon folder
but when i go on my server it dose not work any ideas??
MetalGear
Re: ULX help
« Reply #1 on: October 13, 2007, 11:15:46 am »
also there are no txt files just .lua are there ment to be any txt files
Re: ULX help
« Reply #2 on: October 13, 2007, 11:56:34 am »
You must shutdown and restart your server, and you need ULib for ULX to function.
MetalGear
Re: ULX help
« Reply #3 on: October 13, 2007, 12:33:18 pm »
thats in the ULX folder right dose that have to be in the same folder or 2 diffrent folders like
ULX
ULIB
Re: ULX help
« Reply #4 on: October 13, 2007, 12:36:12 pm »
From your screenshot it doesn't appear to be there.
MetalGear
Re: ULX help
« Reply #5 on: October 13, 2007, 12:44:47 pm »
nvm i got it to work [at last  ;)]
Many thanks
MetalGear
Re: ULX help
« Reply #6 on: October 13, 2007, 12:47:00 pm »
one last thing wile im here
were do i find the admin txt file i found one called  user.txt but it says
//ATTENTION! This is a default file. DO NOT EDIT THIS FILE!!!
//Instead, edit the version in data/ULib/users.txt if it exists. If it doesn't, copy this file over to create it.
//IF YOU MAKE CHANGES TO THIS FILE THEY WILL BE ERASED!
Re: ULX help
« Reply #7 on: October 13, 2007, 02:00:01 pm »
Please read all the instructions in gmod/addons/ulx/ulx_readme.txt
In there it has a link/instructions for how to add yourself as superadmin the easiest way, and the way it describes will also make any -other- mod that doesn't use ULib see you as admin (if admins have extra power for that mod)
