Author Topic: SpaceBuild2 bug and noclip  (Read 9110 times)
Killers
« on: October 14, 2007, 10:15:48 am »
With spacebuild 2 their is planet only noclip option. This allows players to noclip when inside a planet but not when outside also with sbox_noclip 0 it still lets you nocliip  ???
Re: SpaceBuild2 bug and noclip
« Reply #1 on: October 14, 2007, 12:33:48 pm »
 ULX doesn't have/allow non-admins to noclip unless they use the "ulx noclip" command.
If you have UClip, another addon made by Megiddo, (not part of ULX), then remove it for spacebuild2.
If not;
1) Some other mod is causing this.
2) you've somehow edited your groups to allow users to have 'ulx noclip' access,
3) you have a much larger problem where you've given admin access to all your players.
Even if reasons two or three I gave were somehow true, they would all have to type console 'ulx noclip' or chat "!noclip" individually to get noclip access if sbox_noclip 0 were set.
« Reply #2 on: October 14, 2007, 01:12:03 pm »
What the heck? Why'd you post this in SVN? You don't even make any mention of running any of our work, go talk to the other devs if you want help with their work.
« Reply #3 on: October 14, 2007, 01:26:41 pm »
* JamminR chuckles.
I presumed he was running ULX with Spacebuild two and blaming us for his problem.
Killers
« Reply #4 on: October 16, 2007, 12:14:19 am »
Well the planet only noclip works fine without ULX installed so yea i am guessing its a bug with ULX and i posted it in SVN cause i use the SNV vershion
Offline WildWill
  • Global Moderator
    • Beast_Building_Server
« Reply #5 on: October 16, 2007, 04:20:50 am »
I am using the newest version of Spabuild2 and ULX 3.2, If you use the command ulx noclip you can noclip everywhere. If you use the admin controls and enable noclip, then use the command "noclip" in console it is only planetside. Thats how the game is designed and it all seems to be working just fine on my server. So for example, on my server I have noclip enabled but the command "ulx noclip" is not allowed except for admins.
« Reply #6 on: October 16, 2007, 04:26:53 am »
Thanks for the input Will.
Killers. It sounds like another mod conflict or some misconfiguration.
Killers
« Reply #7 on: October 16, 2007, 03:12:29 pm »
I have got ULX noclp admin only tho
« Reply #8 on: October 16, 2007, 04:11:32 pm »
Killers.
I just got off of Will's server.
There is no problem with noclip on his server.
In other words, it isn't a ULX bug. Though your problem MAY somehow involve ULX, it's not due to a bug, but something broken only on your end.
Make sure you do not have UClip listed in your server addons folder.
If you do, remove it.
Killers
« Reply #9 on: October 18, 2007, 01:02:02 pm »
No Uclip...i asked a sb2 dev about it...they said its because ULX dont use standard noclip or something like that...
Anyways i dont have anything but sb2 and ULX that i can see effects noclip...
Il see if i can fix it somehow...
« Reply #10 on: October 18, 2007, 01:26:40 pm »
ULX uses standard noclip.
Killers
« Reply #11 on: October 28, 2007, 04:20:43 pm »
I fixed this after replacing the sb2 game mode on my server maybe i just got a dodgy download.
