Author Topic: New ulx  (Read 4310 times)
Offline ford460ho
New ulx
« on: October 14, 2007, 11:26:32 pm »
Hello im having a little trouble with all the ulx ban. I don't know what i need to do to fix it. ???
Re: New ulx
« Reply #1 on: October 14, 2007, 11:32:22 pm »
What is your trouble?
Also, I believe that there was bug with the ban command that was fixed very recently. I don't know if this update was added to the official download, or if it is just in the SVN...
Try downloading the SVN and see if that fixes your problem..
As for now... the only way to correctly use the Ban command is...
!ban <name> <time> <Reason>
you need to use all of those parameters for the command to work. I believe that the update fixes this where you can use only the parameters that are required.
Re: New ulx
« Reply #2 on: October 15, 2007, 04:01:05 am »
If the player has characters in the name that are hard to type, game console works well too.
ulx ban <name> time reason
When you type in ulx ban, a list of names will autocomplete, allowing you to choose which one, including the difficult to type ones. Just use arrow key to select it, then continue typing time and reason
Offline ford460ho
Re: New ulx
« Reply #3 on: October 15, 2007, 07:33:26 pm »
Ok ill try and see if this fixs it ;)
