Author Topic: Trouble with teams?  (Read 7111 times)
Reinhardt
Trouble with teams?
« on: October 18, 2007, 10:20:04 am »
I thought I took out UTeam, does 3.2 have its own team settings? Like if you have been here for so long your color appears as [such] in the scoreboard?
If so, I made myself a superadmin but the color doesn't change from regular user.
What is going on? Why?
Re: Trouble with teams?
« Reply #1 on: October 18, 2007, 10:37:22 am »
UTeam is nice.. but by itself you will not see colored groups in the scoreboard because the default scoreboard doesnt support it. You should get a custom scoreboard too, sui_Scoreboard is what I use, and it works great.
Reinhardt
« Reply #2 on: October 18, 2007, 10:49:46 am »
Will that fix the fact that it doesn't show me as server admin?
« Reply #3 on: October 18, 2007, 11:39:19 am »
Are you sure you're actually a superadmin? Can you use commands?
« Reply #4 on: October 18, 2007, 05:24:32 pm »
Reinhardt.. yes.. the default ScoreBoard shows everyone as "Player" no matter what your rank is.. this is because you are not a Bot and I believe that the default Scoreboard doesnt support groups...
just my experience.. try sui_Scoreboard.. it'll work for you.
Reinhardt
« Reply #5 on: October 22, 2007, 05:34:40 pm »
Yes, i can use commands, I know i'm superadmin cause when I join it says that I am in the superadmin group.
I installed sui_scoreboard, still no difference, not only that but I can't get any sort of prop protection going, I've tried Simple Prop Protect, and Prop Protection. Nothings working. Should I restart my server and rebuild it? Or get rid of ULX and just redo that?
« Reply #6 on: October 22, 2007, 07:00:33 pm »
Sounds like you might have files from an old mod junking your server. Rebuilding is usually worth the time in situations like these.
Reinhardt
« Reply #7 on: October 22, 2007, 11:10:06 pm »
Grrrr... It's not a dedicated server and It takes forever to ftp my files to it....
Maybe I could get some help as to what files I should put in? Should I do ulx first? and then all my stuff?
Offline Avien
« Reply #8 on: October 23, 2007, 05:50:48 am »
Your stuff might not work because you are not putting them into the addons folders correctly, or are using outdated prop protections that don't support your current version.  I find that this protection, as of right now, is the best and most up to date right now.  http://connacook.com/forums/viewtopic.php?f=50&t=325
