Author Topic: Dedicated admin:ulx 1.11  (Read 10421 times)
Offline Griff
« on: March 06, 2006, 03:21:32 am »
ok, i am having trouble with 1.11. i have created a totaly new dedicated folder just for 1.11, and i have installed ulx on it and also the ulx users builder. i have added my steam id, and the access permisions. loaded the server up. but when i conected to it i couldnt access the admin menu, and whn i typed ulx_who no-one showed up. help please?
Re: Dedicated admin:ulx 1.11
« Reply #1 on: March 06, 2006, 06:54:38 am »
Type status in your server and use the ID that comes from that.
Offline Kenny
« Reply #2 on: March 07, 2006, 10:18:50 pm »
Man, this mod rocks. ;D
Offline Griff
« Reply #3 on: March 08, 2006, 11:06:48 am »
i know how to get my own ID thankyou ^^
i have used the ulx users builder and when i type ulx_who on there i dont apear on the list. here is my current ulx users text.
// Add users here, in the following format:
// "<steamid>" "<access flags>" //Optional comment ( You could say who this steamid belongs to in this comment )
// Example:
// "STEAM_0:1:1234567" "abcdefghijklmnopqrstuz"
// DO NOT INCLUDE THE '//' before the steamid, IT DENOTES A COMMENT
// Access flags:
// a - immunity (can't be kicked/banned/slayed/slapped and affected by other commmands)
// b - reservation (can join on reserved slots)
// c - ulx_kick command
// d - ulx_ban and ulx_unban commands
// e - ulx_slay and ulx_slap commands
// f - ulx_map command
// g - ulx_cvar command (not all cvars will be available)
// h - ulx_cfg command
// i - ulx_chat and other chat commands
// j - ulx_vote and other vote commands
// k - access to sv_password cvar (by ulx_cvar command)
// l - access to ulx_rcon command and rcon_password cvar (by ulx_cvar command)
// m - spawned props will be "protected", only other users with this access will be able to delete or move them ( ALSO UNAFFECTED BY PROP ANTI SPAM )
// n - ulx_ent command - CAUTION, PLAYERS MAY BE ABLE TO CRASH THE SERVER WITH THIS ACCESS
// o - custom level A
// p - custom level B
// q - custom level C
// r - custom level D
// s - custom level E
// t - custom level F
// u - custom level G
// z - custom level H
// TUTORIAL:
// Go to your server, type "status" without the quotes in either your console, or the server console
// Example output:
// Take your steamid. In this example, Joe's steamid is "STEAM_0:1:123456" without the quotes. Use this id as part of your access line.
// In this example, the server admin wants to grant Joe access to the slay-related and kick-related commands ONLY ( the admin looks at the access table listed above and sees that the wanted accesses respond to c and e, respectively ), so the following line ( without the '//' is added to users.ini )
// "STEAM_0:1:123456" "ce"
//"STEAM_ID_LAN" "abcdefghijklmnopqrstuz" //Uncomment this if you want to give people on LAN access, or if you're using the listen server fix
"steam_0:1:6217263" "abcdefghijklmnopqrstuvwxyz"
« Reply #4 on: March 08, 2006, 05:31:04 pm »
STEAM is all capitalized
Offline Griff
« Reply #5 on: March 10, 2006, 10:04:16 am »
ohhhh.. so it needs 2 b capitals...
Offline Golden-Death
  • Honored Lua Scripter
    • BlueFire
« Reply #6 on: March 10, 2006, 03:23:24 pm »
Yeah I thought about making the ulx builder automatically enter the STEAM_ part for you, but I thought itd just end up confusing people.
Offline Griff
« Reply #7 on: March 11, 2006, 09:16:19 am »
ahh, cheers m8, u could put liek a little warning part saying that the words STEAM has to be in capitals perhaps? anyways thankyoyu very much 4 ur help m8.
vash
« Reply #8 on: March 17, 2006, 04:30:39 am »
my ulx admin does not work i try to load it manualy and it still wont work. i get errors in my console about it example:
Lua Error: Line 1: unexpected symbol near '"STEAM_0:0:9338883"'    this is really anoyying i can abuse people for breaking thr rules. plz help. you last commentsd did not help. doi need all the tutorial crap in the folder?
    • BlueFire
« Reply #9 on: March 17, 2006, 06:01:25 pm »
You probably put a bad character in there like a - / " k s or something. You can use this tool to make it for you too.
/index.php/topic,139.0.html
