Author Topic: Admin problems  (Read 19246 times)
Offline Golden-Death
  • Honored Lua Scripter
    • BlueFire
Re: Admin problems
« Reply #15 on: March 28, 2006, 07:29:46 pm »
Well the admins file is correct, in any case...
Re: Admin problems
« Reply #16 on: March 28, 2006, 08:44:01 pm »
There's no random steamid generator in ULX, that id has to be coming from somewhere
Recon77
Re: Admin problems
« Reply #17 on: March 29, 2006, 01:54:43 pm »
well if its not from my users.ini, then where is it from  ??? ???
Offline greenmaster
Re: Admin problems
« Reply #18 on: April 20, 2006, 09:22:36 am »
got the same problem. but my server is a dedicated debian server.
my user.ini input looks like this (only the steamid input rest is allknowns reamdme info)
"STEAM_0:0:263257" "abcdefghijklmnopqrstuz"
and when i try to access adminmenu it says "You lack sufficient access to use this command!"
i try the ULX Builder but the same result :S
Re: Admin problems
« Reply #19 on: April 20, 2006, 12:04:29 pm »
Read the sticky at the top of the thread list.
Offline greenmaster
Re: Admin problems
« Reply #20 on: April 20, 2006, 12:10:38 pm »
i try everything in that list. the status brings up my steamID (post it) and the gusers code doesn`t work. "can only by server admins"
Offline 6igmile
Re: Admin problems
« Reply #21 on: April 20, 2006, 11:22:32 pm »
Hi!
I though you wrotte this   (STEAM_0:0:6147791 00:46)  mine is fine without the  00:46.  try to take out everything and do it again from the begining, or if you know you have everythink correct then you have something (mod, or plugin) you know better, which is making problem with ULX.
Offline greenmaster
Re: Admin problems
« Reply #22 on: April 21, 2006, 12:00:22 am »
i check the steamID double. just as they wrote. i found no problems.
Re: Admin problems
« Reply #23 on: April 21, 2006, 07:17:02 am »
Did you not read the BOLD UNDERLINED part that said RUN THIS COMMAND AT THE SERVER CONSOLE? Or that part that said to make a thread with that information? This thread is now locked due to stupidity.
