Author Topic: Vehicle Limitation  (Read 6081 times)
Offline Leaky
Vehicle Limitation
« on: April 01, 2006, 07:01:10 pm »
I just started playing Gmod so I had to make a server...only prob is I still don't know much about out. I have ulx installed but I want to set it to allow vehicles....right now only the pod vehicle can be spawned. Where is the config to allow 1 of each vehicle per player to be spawned?
Leaky
Re: Vehicle Limitation
« Reply #1 on: April 01, 2006, 07:56:18 pm »
If you're running a dedicated server, you need the dedicated server vehicle fix. Check on the VALVe forums for the fix.
