Author Topic: ulx_ent Command  (Read 6194 times)
Offline Chicken132
ulx_ent Command
« on: April 28, 2006, 06:12:40 pm »
I have been setting up a large amount of path tracks in configuration files to be executed and spawn a path_track with the specified keys and values problem is the entities are supposed to stay at the player origin, and I can't for the life of me figure out how to set ulx to spawn the entity at user origin is there any way to do this.
I was looking at the code for the ulx_util.lua
function cc_ulxEnt( userid, args, argv, argc )
   ulx_log( "Admin " .. ulx_playerString( userid ) .. " created an ent, using these arguments: " .. args ) -- Log first incase it crashes
   local class = argv[ 1 ]
   table.remove( argv, 1 ) -- We already have the first now
   newEnt = _EntCreate( class )
   local pos = _PlayerGetShootPos( userid )
   local ang = _PlayerGetShootAng( userid )
   _TraceLine( pos, ang, 4096, userid )
   local vector = _TraceEndPos()
   vector.z = vector.z + 20
   debug( tostring( vector ) )
   _EntSetKeyValue( newEnt, "origin", vector.x .. " " .. vector.y .. " " .. vector.z ) -- Note that the position can be overridden by the users's flags
   for i,v in ipairs( argv ) do -- Loop through them
      local key = string.sub( v, 1, string.find( v, ":" ) - 1 )
      local value = string.sub( v, string.find( v, ":" ) + 1 )
      _EntSetKeyValue( newEnt, key, value )
   _EntSpawn( newEnt )
ULX_CONCOMMAND( "ulx_ent", cc_ulxEnt, ACCESS_ENT, "<classname> <flag> .. - spawn an ent, separate flag and value with : ( IE: ulx_ent prop_ragdoll model:models/alyx.mdl )", 1 )
This portion of the line
leads me to believe that you can some how
if it isnt possible with the current command code is it possible for someone to rewrite the code here to do so so that i can add it to the ulx_util.lua file as another command
Thanks
Re: ulx_ent Command
« Reply #1 on: April 28, 2006, 06:27:50 pm »
It wouldn't be possible directly from console... but in lua:
[lua]
   newEnt = _EntCreate( "path_track" )
   _EntSetKeyValue( newEnt, "origin", pos.x .. " " .. pos.y .. " " .. pos.z )
[/lua]
And then set any other keyvalues you want as well.
Offline Chicken132
Re: ulx_ent Command
« Reply #2 on: April 28, 2006, 06:47:52 pm »
Now if I wanted to keep the entity creation so that I would be able to spawn different entities other than just path_track i should keep the "path_track" at "class" instead of replacing it with "path_track".
Also since I am most likely not the only one that would need this is it possible that this could be added to the next release as well?
Thanks Meg
Btw that Ultimate NPC Spawning Script for version 7 totally kicked ass Great work
