Author Topic: Map menu problem, and a question  (Read 8605 times)
adamscybot
« on: May 14, 2006, 01:08:04 am »
Ive got 2 things to say. Keep in mind, I've never used ULX before. I hvae it installed on my 4-man Gmod server.
1) When I select map menu, nothing happens. The menu just slides out of the screen and nothing comes up. Why? Do I have to configure this menu myself...if so, how.
2) On my server, I am pretty sure that anyone who joins can access the client menu. This allows them to kick/kickban players! How do I stop normal users having this function. I tihnk they shouldnt even be allowed to slap someone...lol
Please point me in the right direction, as I have no idea how I change these things. I have only added the admins to users.ini so far.
Adam
Re: Map menu problem, and a question
« Reply #1 on: May 14, 2006, 05:35:22 am »
1. The map menu was moved to the spawn menu
2. Did you give access to STEAM_ID_PENDING ?
adamscybot
« Reply #2 on: May 14, 2006, 11:31:32 am »
Sorry to be such an incredible n00b. But how do I gett he spawn menu up. I cant see it as an option in ulx_menu.
As for the STEAM_ID_PENDING issue - ignore it. Only admins can access it now. Just this darn spawn menu issue!
Adam
« Reply #3 on: May 14, 2006, 01:50:02 pm »
Press 'q' to see the spawn menu.
adamscybot
« Reply #4 on: May 14, 2006, 01:58:44 pm »
O, lol. Obvious, didnt tihnk it would be.
How do i remove the maps option for cleanliness?
« Reply #5 on: May 14, 2006, 05:32:52 pm »
Delete ulx_menus.lua
adamscybot
Fixed!
« Reply #6 on: May 15, 2006, 11:17:40 am »
I didnt delete ulx_menus.lua because i realise that you would end up with no menus at all! I only wnated to get rid of the unworking map menu from the ulx_mneu command.
I fixed it now. To anyone who may ask the same quesiton in the future you need to find and delete this line in ulx_menus.lua:
addOption( userid, "Maps Menu", ID_MAPSMENU, ACCESS_MAP )
Adam
Offline Technical Unit
« Reply #7 on: May 16, 2006, 03:11:21 am »
Adam
Adam Nobody is a Noob
We are all here to Teach things ::)
