Author Topic: Having Some Touble  (Read 5406 times)
Offline Sabre
Having Some Touble
« on: May 25, 2006, 06:53:19 am »
I have ULX installed and everything and it all works on on gm_construct but on other maps like football, ulx doesn't seem to be installed. If I type ulx_menu or anything of that nature in the console on anything other than construct it doesn't work the only thing that works on maps other than construct is the say commands such as "@@@ This is the admin"
Any know why this is?  :)
] status
hostname:  Bewdley G-Mod Server
version   : 1.0.1.0/7 2707 insecure (secure mode enabled, connected to Steam3)
udp/ip  :  192.168.0.2:27015
map     :  gm_construct at: 704 x, 132 y, -79 z
players :  1 (6 max)
# userid name uniqueid connected ping loss state adr
#  2 "Sabre" STEAM_0:0:9306985 00:12 42 0 active 127.0.0.1:27005
« Last Edit: May 25, 2006, 06:59:45 am by Sabre »
Re: Having Some Touble
« Reply #1 on: May 25, 2006, 07:22:49 am »
It could be for a number of reasons, most likely the other gamemodes are overriding a lot of ULX's functions. I specifically did not test ULX on any other map but construct for this reason.
Offline Sabre
« Reply #2 on: May 25, 2006, 10:18:41 am »
Thank You for the reply Megiddo I am much looking forward to 1.2 I think your work is great!  ;)
Any hints on when your going to release it?
