Author Topic: How to use adverts?  (Read 32507 times)
Offline jesus
How to use adverts?
« on: November 12, 2005, 03:25:21 pm »
My Adverts ARE working now, as well as everything else, amazing work guys!!
« Last Edit: November 20, 2005, 02:35:18 pm by jesus »
Offline Golden-Death
  • Honored Lua Scripter
    • BlueFire
Re: How to use adverts?
« Reply #1 on: November 12, 2005, 03:58:19 pm »
Go to lua/ulx/ulx_config.lua and follow the directions in there
« Reply #2 on: November 12, 2005, 05:50:29 pm »
Also make sure you're using v0.81+ or it won't work.
Offline jesus
« Reply #3 on: November 13, 2005, 04:14:50 am »
Yeah i'm using 8.1, when you install it you have one test add in there right?
So when I start a server what do I do to enable them? (Nothing came up by default)
« Reply #4 on: November 13, 2005, 08:18:44 am »
Sorry, turns out that function isn't working for some reason. You can call the addAdvert() and addCsayAdvert() directly and it should work, however.
Offline jesus
« Reply #5 on: November 14, 2005, 09:52:19 am »
OK...
I have 0.9
And I use this:
function ulx_loadConfig( name, userid, steamid )
   if gConfigLoaded == true then
      return -- Already loaded
   -- Adverts
   -- addCsayAdvert( msg, r, g, b, repeat_time, length )
   -- addAdvert( msg, repeat_time )
   -- You can use %hostname%, %curmap%, and %nextmap% in your text and have it automaticly parsed for you
   addCsayAdvert( "Welcome to %hostname%, enjoy your stay!", 100, 255, 200, 300, 5 )
   addAdvert( "Remember to play nicely!", 360 )
   addAdvert( "Jesus is admin on this server.", 613 )
   addAdvert( "Red team = Admin, yellow = VIP and blue = Normal.", 605 )
   addCsayAdvert( "The map you are playing on is %curmap%", 100, 255, 200, 150, 5 )
   gConfigLoaded = true
But nothing comes up.
If i'm doing something wrong please tell me exactly what to type into the console to activate it.
Offline Mank
    • Ulysses Mod!
« Reply #6 on: November 14, 2005, 01:14:32 pm »
OK...
I have 0.9
And I use this:
You're a beta tester?
Offline jesus
« Reply #7 on: November 14, 2005, 01:27:30 pm »
No, 0.9 has been released to the public.
But can anyone help??
Offline Mank
    • Ulysses Mod!
« Reply #8 on: November 14, 2005, 02:06:44 pm »
Oh, I didn't read the main site.
« Reply #9 on: November 14, 2005, 03:08:20 pm »
OK...
I have 0.9
And I use this:
You're probably just not noticing it come up :-P . If you leave your console for a while and come back, you should see the messages in your console. ( Or you could set the time to 10 seconds to doubly make sure it's working )
Offline jesus
« Reply #10 on: November 15, 2005, 08:18:05 am »
Wait, these messages will come up on screen like ulx_csay right?
EDIT: I did that, I set them to intervals of 5, and 10 etc.
Nothing came up, in the console or on screen.
« Last Edit: November 15, 2005, 09:33:03 am by jesus »
Offline jesus
Re: How to use adverts? (EDITED)
« Reply #11 on: November 20, 2005, 02:34:57 pm »
« Reply #12 on: November 20, 2005, 03:53:18 pm »
So what was the problem?
Offline jesus
« Reply #13 on: November 20, 2005, 04:36:19 pm »
Basically not all the 0.81 files were overwritten by the 0.90 files and so it actually loaded half 0.90 and half 0.81
I first noticed that this was the problem when I had ulx_weaponmenu on the ulx_help but it wouldn't load, this also caused errors with my melonrace and votemap changes.
Sorry for the trouble.
« Last Edit: November 20, 2005, 04:38:08 pm by jesus »
