Author Topic: Admins?  (Read 6263 times)
Offline puregreen
Admins?
« on: October 27, 2007, 05:02:21 pm »
Hey, i am new to all of this, but im very fast Lerner, I have it all installed but it just Tells me in a Reguler user what ever i seem to do : ( can someone tell me the formate that your ment to put your SteamID in? i just wnat to have Full Acsess over it
It is installed on a dedicated Server
Hope some one can help,
Thanks
Re: Admins?
« Reply #1 on: October 27, 2007, 05:15:19 pm »
Your question is probably answered in our access sticky.
If it doesn't answer your question or you need further help, please make sure you post the information it asks for into this thread. If you don't post the information it asks for, you will be ignored.
Re: Admins?
« Reply #2 on: October 27, 2007, 06:35:54 pm »
IF you have access to the server console type
ulx adduser yourname superadmin (Type this in the server console.. not your game's console)
and it will add you to the admin list...
If you have RCON access but not direct access to the server console... (if you are buying the server from a provider) type the following in your game console...
rcon_password yourRConPassword  (You may need to ask your provider what it is if you dont know)
rcon ulx adduser yourname superadmin
Both of those are typed in your game console and that is essentially how you enter commands in the server console if you dont have direct access to it.
Offline MasterMike
Re: Admins?
« Reply #3 on: October 29, 2007, 12:48:09 pm »
I get
"Results:
Unable to connect to remote server (0.0.0.0:0)"
Offline spbogie
Re: Admins?
« Reply #4 on: October 29, 2007, 01:33:53 pm »
you have to be connected to your server, or enter the ip of your server in rcon_address before attempting to run rcon commands.
Offline MasterMike
Re: Admins?
« Reply #5 on: October 29, 2007, 03:02:21 pm »
Ok... Now i get
] rcon ULX adduser MasterMike superadmin
] rcon_address *******
] rcon_password ******
autokick is disabled for MasterMike (Zombie Fleet)
Thats in game consol
And nothing happens in rcon box on server
Offline spbogie
Re: Admins?
« Reply #6 on: October 29, 2007, 03:28:14 pm »
You need to be on your server at the time you run the command to add yourself as a user through ULX, in which case you shouldn't need the rcon_address set. Regardless, nothing will show up in the RCON box on your Web Control Panel, because rcon is based on individual connections. If you are on the server when you run the command, and the name you enter matches all, or part, or your screenname on your server, and doesn't match anyone else on the server at the same time, you will be added as an admin.
So, here are your steps:
1) Connect to your server from within gmod.
2) Open console and enter "rcon_password <your pass here>"
3) Enter "rcon ulx adduser <your name here> superadmin"
4) You should get a response back from the server.
5) It may tell you to run a different command before you can run adduser. If so run this command through rcon ("rcon <command it told you to run>"), then run the add user command again.
6) You should now have access. If not then please read the first topic under Important Topics on this subform "Having trouble with access?", and complete all steps.
7) If you get here and it isn't working, then you should have provided us with some specific information to help you. If you have not then return to step 6 as you have not completed it correctly.
Re: Admins?
« Reply #7 on: October 29, 2007, 07:56:18 pm »
This shows that you were noticed when you ran the command.. it should have worked... try running an admin command.. '!slap mastermike' and see if it works..
