We understand english may not be your native language.
That is fine.
However, I have a hard time understanding you.
Are you trying to say;
1) You are getting "scriptenforcer" errors?
and
2) "ulx menu" only gives you "motd" as the only option?
My answer to those;
1) Ulx is not made to block any other script from loading. If you have script enforcer enabled, you will need to add the individual files to the scriptenforcer system.
Please post any console errors you are getting.
2) Either #1 is causing you not to get admin, or, you've not added yourself properly. Fix #1 (and if after you fix #1 still not admin, then
/index.php/topic,383.0.html )
