Suggestions
PHP Support in the MOTD
Topic: PHP Support in the MOTD (Read 5888 times)
Killers
Guest
October 29, 2007, 05:32:11 pm »
PHP to be Support in the MOTD
spbogie
Ulysses Team Member
Sr. Member
Re: PHP Support in the MOTD
October 29, 2007, 07:25:58 pm »
The MOTD uses the built in HTML VGUI control. I don't remember if we support pointing to an external website for the MOTD (if not we should), but the only way to use PHP is to host your MOTD on a webserver with PHP installed.
JamminR
Ulysses Team Member
Sertafide Ulysses Jenius
Reply #2 on:
October 30, 2007, 05:34:36 am »
A bit more clear to those who don't understand... PHP is 'WEB' server side scripting. The Gmod motd file you view is treated as a client side. All the gmod server does is attempt to feed it to you in raw format. No "real" language parsing is done before it gets fed.
Suggestions
