Author Topic: Can you set server defaults with ULX  (Read 13586 times)
John
« on: October 30, 2007, 02:35:59 pm »
Probably a stupid question, but I need to figure out how to set the default amount of set props etc, and find a way to have users spawn with no weapons.
Anyone feel like helping?   ???   :D
Re: Can you set server defaults with ULX
« Reply #1 on: October 30, 2007, 02:48:02 pm »
Answer 1: http://garrysmod.com/wiki/?title=Admin#Setting_Limits
Answer 2: I don't know of anything that makes users spawn with no weapons, sorry.
Offline MulleDK13
« Reply #2 on: October 30, 2007, 02:58:12 pm »
To the no weapons question. I think I got the answer (by accident)..
local function noWeaponsSpawn( ply )
return ""
hook.Add( "PlayerSpawn", "ULXNoWeaponsSpawn", noWeaponsSpawn, -15 ) -- Very low priority
Just put that at the bottom of fun.lua located in ulx\lua\ulx\modules
or create a new module... This works but you won't even have the phys gun! so you would need to spawn that somehow!
Offline spbogie
« Reply #3 on: October 30, 2007, 03:09:05 pm »
2) Put this in a file named "limitedloadout.lua" in gmod/lua/autorun/server
local weapons = { "weapon_physgun", "weapon_physcannon", "gmod_camera", "gmod_tool" }
local function LimitedLoadout( ply )
for _, v in pairs( weapons ) do
ply:Give( v )
  ply:SelectWeapon( weapons[ 1 ] )
  return true
 hook.Add( "PlayerLoadout", "LimitedLoadout", LimitedLoadout)
Place any weapons you want people to spawn with in the weapons table.
weapon_physgun = Phys Gun
weapon_physcannon = Grav Gun
gmod_camera = Camera
gmod_tool = Tool Gun
« Last Edit: October 30, 2007, 03:11:23 pm by spbogie »
John
« Reply #4 on: October 30, 2007, 06:31:09 pm »
Wow, thanks for the quick, good replies guys, I'll go test this now.
Offline Avien
« Reply #5 on: November 02, 2007, 11:01:22 pm »
If on a dedicated server:
Simply edit the file garrysmod/gamemodes/sandbox/gamemode/init.lua
function GM:PlayerLoadout( pl )
// Remove any old ammo
pl:RemoveAllAmmo()
if ( server_settings.Bool( "sbox_weapons", true ) ) then
pl:GiveAmmo( 256, "Pistol", true )
pl:GiveAmmo( 256, "SMG1", true )
pl:GiveAmmo( 5, "grenade", true )
pl:GiveAmmo( 64, "Buckshot", true )
pl:GiveAmmo( 32, "357", true )
pl:GiveAmmo( 32, "XBowBolt", true )
pl:GiveAmmo( 6, "AR2AltFire", true )
pl:Give( "weapon_ar2" )
pl:Give( "weapon_crowbar" )
pl:Give( "weapon_pistol" )
pl:Give( "weapon_smg1" )
pl:Give( "weapon_frag" )
pl:Give( "weapon_physcannon" )
pl:Give( "weapon_crossbow" )
pl:Give( "weapon_shotgun" )
pl:Give( "weapon_357" )
pl:Give( "weapon_rpg" )
// The only reason I'm leaving this out is because
// I don't want to add too many weapons to the first
// row because that's where the gravgun is.
//pl:Give( "weapon_stunstick" )
pl:Give( "gmod_tool" )
pl:Give( "gmod_camera" )
pl:Give( "weapon_physgun" )
local cl_defaultweapon = pl:GetInfo( "cl_defaultweapon" )
if ( pl:HasWeapon( cl_defaultweapon )  ) then
pl:SelectWeapon( cl_defaultweapon )
Just simply remove the items you don't want, or change how much ammo you start with...
You can also add in a line saying if the player's steamid is not an admin id, then remove the weapons, else spawn with them all.
« Reply #6 on: November 03, 2007, 10:26:47 am »
I was under the impression that Garrysmod no longer allowed editing of the 'default' files.
Thought that was done by Garry to prevent all the broken ways people were coding various things.
Offline spbogie
« Reply #7 on: November 03, 2007, 10:31:14 am »
It does not allow editing of the default files on the CLIENT, however, SRCDS does not use gcf files, so it is imposible for him to force an override there.
« Reply #8 on: November 03, 2007, 10:32:59 am »
Gotcha. I was wondering if that was the case. Thanks for verifying Spbogie
meeces2911
« Reply #9 on: January 06, 2008, 10:58:03 pm »
ply:Give( v )
  return true
I like spbogie idea, but it dosnt work ... :( does anyone have a working copy of this ??
meeces2911
« Reply #10 on: January 07, 2008, 10:08:18 pm »
Nevermind, i found another way, modifying the Uteam function to accept weapons... :)
