Author Topic: Ulx And Dark Rp  (Read 23333 times)
Offline PGast
Ulx And Dark Rp
« on: November 07, 2007, 12:19:35 pm »
Hey I recently rented out a server at ArtOfWarcentral.com... They added Ulib and Ulx and Dark Rp v2.1 onto my server. However ULX admin wont work on Dark Rp.. It would work for me on Regular Game mode (Sandbox). but Not dark rp. Please Help!
Re: Ulx And Dark Rp
« Reply #1 on: November 07, 2007, 12:34:00 pm »
what about it doesn't work? Certain commands? Chat commands? everything?
Do you get any errors?
Have you tried turning it off.. and back on? (  ;D j/k )
a little more information will make helping you a little more easy! =)
Offline PGast
Re: Ulx And Dark Rp
« Reply #2 on: November 07, 2007, 06:13:53 pm »
It says Im not able to use that command.. BUt when i join it says welcome Pgast your super admin
Offline PGast
Re: Ulx And Dark Rp
« Reply #3 on: November 07, 2007, 06:38:56 pm »
ON all codes
Re: Ulx And Dark Rp
« Reply #4 on: November 08, 2007, 05:59:58 pm »
Please see this post. Try all steps. Come back with the info it asks for if the steps don't work.
Please don't lie and say "I've done it all already".
If you had, we'd know. There is a lie detector embedded within it.
Offline PGast
Re: Ulx And Dark Rp
« Reply #5 on: November 08, 2007, 09:23:17 pm »
Hey  everything else is right but... When I did Rcon Gamemode_reload this poped up..
autokick is disabled for Pgast
SERVER: Reloading Gamemode..
SERVER: -----------------------------------------
SERVER: - RUN ERROR
SERVER: - File: DarkRP/gamemode/init.lua
SERVER: - Path: DarkRP/gamemode
SERVER: - rplol.lua:151: attempt to index local 'player' (a nil value)
SERVER: **********************************************
SERVER: ********** COULDN'T LOAD GAMEMODE!! **********
SERVER:
There was a problem opening the gamemode file 'DarkRP/gamemode/init.lua'
Registering gamemode 'DarkRP' derived from 'sandbox'
ScriptEnforce: gamemodes/DarkRP/clientscripts.txt wasn't found. This gamemode is unprotected.
Re: Ulx And Dark Rp
« Reply #6 on: November 08, 2007, 10:04:12 pm »
Did you not say in your OP that everything worked fine in Sandbox but not when you run Dark RP.. maybe you either have a bad version of Dark RP or there is something in it that conflicts with the accesses in ULX.
Unfortunately I don't think if that is the case, there is anything that can be done on this side to help you.. Maybe get in contact with the maker(s) of Dark RP and see if they know of any conflicts with ULX.
Re: Ulx And Dark Rp
« Reply #7 on: November 08, 2007, 10:35:06 pm »
It looks like something is removing the player library...
Offline spbogie
Re: Ulx And Dark Rp
« Reply #8 on: November 09, 2007, 08:09:23 am »
If ulx is running then please enter "ulx debuginfo" in the SERVER console (RCON) and come back with the output. (output will be to file)
If not then please put together a list of all addons you are using (along with their version if possible (see info.txt)).
Offline PGast
Re: Ulx And Dark Rp
« Reply #9 on: November 09, 2007, 11:57:40 am »
Hey it says pgast is disabled for autokick
and thats it..
Im running Drk Rp 2.1 Garrysmod.org
Ulx and Ulib Newest version thats on site.
and thats it...
Re: Ulx And Dark Rp
« Reply #10 on: November 09, 2007, 12:24:27 pm »
Follow these instructions.
Offline PGast
Re: Ulx And Dark Rp
« Reply #11 on: November 09, 2007, 12:30:40 pm »
I Did.  AND  I Did Put The Mods I have on The server. However Im installing Dark Rp 2.2 and removing Dark Rp 2.1 I want to see if it is the Dark rp 2.1 problem. It said to me when i typed that code you told me in. that Pgast is disabled for autokick
Offline PGast
Re: Ulx And Dark Rp
« Reply #12 on: November 09, 2007, 12:42:47 pm »
How ever anyone know any other site then Garrysmod.org ??
I need to get Dark rp vs... and Garrysmod.org is a bad version
Offline PGast
Re: Ulx And Dark Rp
« Reply #13 on: November 09, 2007, 02:52:34 pm »
Kk i reinstalled another dark rp . different download ..
and it still wont let me use commands now when i go into rcon with password and type
rcon gameload_reload
it says same message as before!>
also  when i logg in it says welcome garry your super admin on this server.
And it says on console below that
Warning: Unhandled usermessage 'ulx_resetinfo'
Warning: Unhandled usermessage 'ulx_autocomplete'
Also my name is Pgast oNgame not sure if that matters
Re: Ulx And Dark Rp
« Reply #14 on: November 09, 2007, 03:24:00 pm »
Are you using script enforcer?
