Author Topic: LAN server  (Read 5056 times)
PC
LAN server
« on: November 27, 2007, 04:10:17 pm »
Is there any way to get a friend to be a superadmin on my LAN server?
Re: LAN server
« Reply #1 on: November 27, 2007, 08:23:41 pm »
Are you running ULX?
If you are just simply type "ulx adduser friendsname superadmin"
Done! =)
Offline spbogie
Re: LAN server
« Reply #2 on: November 27, 2007, 08:47:03 pm »
The problem is that adduser uses steamids, and in LAN all steamids are STEAM_ID_LAN. You can add the users based on IP, or name, but to do so you will need to actually edit the data/ULib/users.txt file manually. If you are going to be playing with other people who you do not want to be able to get superadmin access then I recommend using a password for his account. Also, if you are going by IP then you should set his computer up with a static IP address so you don't have to change the ip in users.txt every time his ip changes.
« Last Edit: November 27, 2007, 08:48:44 pm by spbogie »
Re: LAN server
« Reply #3 on: November 27, 2007, 11:17:06 pm »
I read LAN server as Listen Server.. Oi! :D
PC
Re: LAN server
« Reply #4 on: November 28, 2007, 07:11:38 am »
Thank you guys, great to know that there is some people who can help with this, cya later ;D
