Author Topic: ulx showMotd 0 doesn't work  (Read 7094 times)
Geoff
« on: November 29, 2007, 09:22:26 pm »
Hi guys, I'm having trouble getting ulx showMotd 0 to work. I have it set so in the server.ini file of the ulx\config folder, and it still is shown on connect. I also tried setting it this way via console but with no luck. I tried both the offical 3.20 AND svn versions and this happens. :(
Is there something i'm missing that I am supposed to do? thanks for any help!
Re: ulx showMotd 0 doesn't work
« Reply #1 on: November 29, 2007, 09:30:56 pm »
Works for me
Geoff
« Reply #2 on: November 29, 2007, 09:42:27 pm »
I don't get what could be wrong then, i've tried re-installing it multiple times. Is it maybe because I use it on a listen server? I have made 100% certain it's set to zero but it still shows up in single player and when i make a server. :(
« Reply #3 on: November 29, 2007, 09:53:45 pm »
listen servers dont read the server.ini file correctly if I remember right.
Maybe one of the devs can confirm this..
« Reply #4 on: November 29, 2007, 11:00:27 pm »
Yes, it doesn't read from server.ini on first map load right now. Will work after that though.... If you're hosting a listen server you'll still see the motd because the config is applied after you join.
« Reply #5 on: November 30, 2007, 12:46:13 am »
Geoff, have you tried SVN since 11-23?
Megiddo has the issue marked as resolved on our bug tracker.
http://www.ulyssesmod.net/bugs/view.php?id=151&nbn=2#bugnotes
Megiddo, if he answers yes, I'll test myself. Might need to re-open.
« Reply #6 on: November 30, 2007, 07:55:12 am »
Doesn't matter at this point anyways, we're going to have to refactor all the initialization code with this upcoming gmod release.
Geoff
« Reply #7 on: November 30, 2007, 09:31:43 pm »
Oh, that make sense. It's not TOO much of a bother I just thought there may have been a problem or I was doing something wrong.
Thanks for clearing it up. :D
