Author Topic: restricted banning by group  (Read 8534 times)
Offline blacksythe
« on: December 02, 2007, 12:54:14 pm »
I would like to see the ability to give out restricted time bans based on a group for example.
Operators can ban for up to 3 days maximum,
Moderators can ban for upto 1 week maximum
admins 1 month/ perma
Sadmins perma ban
Or if someone can give me some code so i can implement this myself I would much appreciate because soon i am moving onto a multi server administration and would like moderators to head servers admins to head all servers etc.
Re: restricted banning by group
« Reply #1 on: December 02, 2007, 03:57:16 pm »
I think this is a good idea. Something for a module, for sure.
As for implementation... you could copy and paste the code for the ulx ban command and throw in a couple of lines of code that checks the time parameter and only goes through it if is within a certain range like...
if (time <= 4320) and (time > 0)
Ban Function
Echo to the screen that the time does not meet the requirement
You could then call it something like... mban (moderator ban) or oban (operator ban)
**That is not lua btw.. I'm not good with lua syntax unfortunately.**
« Reply #2 on: December 05, 2007, 12:48:14 am »
Here you go.
function ulx.cc_ban2( ply, command, argv, args )
if #argv < 1 then
ULib.tsay( ply, ulx.LOW_ARGS, true )
return
local target, err = ULib.getUser( argv[ 1 ], _, ply )
if not target then
ULib.tsay( ply, err, true )
return
local bantime = tonumber( argv[ 2 ] ) or 0
if bantime == 0 then
ULib.tsay( ply, "This ban is not allowed to ban perminently", true )
return
if bantime > 4320 then
ULib.tsay( ply, "This ban is not allowed to ban for longer than 3 days", true )
return
local dummy, dummy, reason = args:find( "^\"*" .. ULib.makePatternSafe( argv[ 1 ] ) .. "\"*%s+" .. ULib.makePatternSafe( argv[ 2 ] ) .. "%s+(.*)$" )
reason = reason or "" -- Make sure it has a value
local time = "for " .. bantime .. " minute(s)"
if reason ~= "" then reason = "(" .. reason .. ")" end
ulx.logUserAct( ply, target, "#A banned #T " .. time .. " " .. reason )
ULib.kickban( target, bantime, reason, ply )
ulx.concommand( "ban2", ulx.cc_ban2, "<user> [<time>] [<reason>] - Bans a user for x minutes, Must be less than 4320 minutes(3 Days).", ULib.ACCESS_ADMIN, "!ban2", _, ulx.ID_PLAYER_HELP )
All I did was add 2 time checks =)
ulx ban2 <user> <time> <reason> (!ban2)
This ban can not ban for 0 minutes (perminently).. if you try it will tell you you cant and exit the function
This ban can not ban for more than 3 days.. if you try it will tell you it cant, and exit the function.
If you want to call it something else.. like aban or oban.. or whatever.. just open the lua file in notepad and replace all 4 instances of ban2 with whatever you want it to be called. The Find and Replace function under Edit works wonders for this! =)
Download below..
oh btw.. drop this in Addons/ULX/Lua/ULX/Modules
« Last Edit: December 05, 2007, 12:50:27 am by zakap »
« Reply #3 on: December 05, 2007, 07:43:07 am »
Don't burn yourself out Zakap! ;)
Offline blacksythe
« Reply #4 on: December 05, 2007, 09:13:28 am »
wow cheers looks greatand works great too
« Reply #5 on: December 05, 2007, 02:06:38 pm »
lol, Meg. You have no idea how much I've always wanted to do.. but was always too afraid to do it because I was scared of lua Syntax... =)
