Author Topic: modifying simple propprotection  (Read 4870 times)
Offline blacksythe
« on: December 08, 2007, 02:02:10 pm »
Id like to modify it to allow moderators to move peoples props
Re: modifying simple propprotection
« Reply #1 on: December 08, 2007, 08:57:43 pm »
I tried this just a few minutes ago for my server.. I found it was MUCH MUCH easier to make your moderator group teh admin group.. and then all groups higher than them just inherit the admin group. That way when the script performs the IsAdmin check, it'll allow them.
Just go into your groups.txt file and only allow the command you want to have moderators do... make sure you put the rest in superadmin group because it inherits the admin group and if you just go removing thigns from admin, you'll find you wont have them on superadmin either.
Offline blacksythe
« Reply #2 on: December 09, 2007, 05:28:29 pm »
Ill have a play around with the settings sounds like a good idea maybe ill name the new admin group admin0 and have uteam display them as admins along with admin as moderator. Ill also use gmods default to bypass the admins not being able to use spp.
