Author Topic: Restarting the server remotely  (Read 6007 times)
Billy9205
« on: December 18, 2007, 08:20:36 pm »
How do u restart a Gmod dedicated server remotely? i downloaded the ULX update and i need to restart.
Re: Restarting the server remotely
« Reply #1 on: December 18, 2007, 08:30:25 pm »
if you have access to your RCon send it the exit command. Then assuming you/your host provider has a restart script set up.. it'll restart. Otherwise you can't, unless your host has some sort of server control panel installed.. Like TCAdmin (which is what I use)
Offline louis
« Reply #2 on: December 27, 2007, 02:42:32 am »
Well i know this is not the answer you need but i use www.GModservers.com free server [but now i upgraded to the full version payed] its the same layout of steams dedicated server i just close it and open it back up  ::)
