Author Topic: admin problem  (Read 7726 times)
Offline jelle
admin problem
« on: December 22, 2007, 05:28:05 am »
hey everybody,
I have a big problem.
i have a gmod server (not dedicated, list) and when someone joins that person is admin.
Everbody who joins is admin.
How can i change that?
i only wanna have one admin, and that is me.
So, please help!!! :'(
Re: admin problem
« Reply #1 on: December 22, 2007, 11:22:45 am »
Is this a LAN server?
Offline zerofreeze
Re: admin problem
« Reply #2 on: December 30, 2007, 12:59:16 pm »
hey everybody,
i have the same problem and it really is annoying because today a guy saw he was admin and banned someone for fun  >:(
Re: admin problem
« Reply #3 on: December 30, 2007, 01:02:30 pm »
Re: admin problem
« Reply #4 on: December 30, 2007, 01:49:04 pm »
This sounds like the original post was a "listen".
I can't speak for them though.
A post and run it seems.
Offline zerofreeze
Re: admin problem
« Reply #5 on: December 30, 2007, 01:52:02 pm »
i started lan but then i typed sv_lan 0 so then it comes up in the internet list does anybody know how to fix this problem
Re: admin problem
« Reply #6 on: December 30, 2007, 01:54:52 pm »
Edit gmod/cfg/server.cfg .. if it doesn't have sv_lan, then add it and make sure it says sv_lan 0
Offline zerofreeze
Re: admin problem
« Reply #7 on: December 30, 2007, 02:01:53 pm »
i see sv_lan 0 but i want to fix the problem that i only can be admin because every guy who joins is admin ???
Re: admin problem
« Reply #8 on: December 30, 2007, 02:15:02 pm »
This is 99% most likely a problem on your side.
1) Are you running a hacked copy of Steam/HL2/Gmod? If so, this can cause all to have admin. No way to fix this (at least, no way we support)
(NOT saying you are... just a possibility)
2) Some gamemodes/addons break the admin checks of ULX/ULib. We've recently discovered problems with DarkRP.
If not the mod itself, then perhaps the way you have configured it. (even ULib itself perhaps)
2) Make sure you've followed EVERY instruction of our sticky titled "Having trouble with access?" in the Help and support forum here.
We know if you haven't, it has a lie detector test in it.
No, seriously. If you don't follow every instruction, we know.
Offline zerofreeze
Re: admin problem
« Reply #9 on: December 30, 2007, 03:03:22 pm »
I have a cracked gmod so nvm for the server ill just play
