Author Topic: Can i make Ulx?  (Read 19696 times)
Offline louis
Can i make Ulx?
« on: December 29, 2007, 09:54:00 am »
evertime i restart my server i need to type in net_maxfilesize 55 because the map is larger than the download limit so evertime i restart my server can i make ulx say net_maxfilesize 55 into the server console for me like it does with Forcedownload
Thanks
Re: Can i make Ulx?
« Reply #1 on: December 29, 2007, 12:27:16 pm »
You could, but for items like that it would be easier not to.
Server.cfg is the file you need to download/edit.
All Source servers use that file, gmod or not.
Please, learn to use the server before using ULX.
http://garrysmod.com/wiki/?title=Dedicated_Server_Setup - decent start. Has several server.cfg listings and file to download for basic.
Google server.cfg as a secondary
Offline louis
Re: Can i make Ulx?
« Reply #2 on: December 29, 2007, 01:39:41 pm »
??? im allready running my server will ulx and its all running fine. p.s that did not answer my question
Re: Can i make Ulx?
« Reply #3 on: December 29, 2007, 02:07:01 pm »
p.s. You didn't ask a question.
Offline louis
Re: Can i make Ulx?
« Reply #4 on: December 29, 2007, 02:13:56 pm »
Thanks
you sure....
Re: Can i make Ulx?
« Reply #5 on: December 29, 2007, 02:40:59 pm »
yeah, pretty sure a question has a question mark.
this thing.. ????????
add that line to your server.cfg file.
^^ That answers your run-on sentence. ^^
Re: Can i make Ulx?
« Reply #6 on: December 29, 2007, 03:16:11 pm »
Not only did I answer your question;
<clip>
I gave more information that would probably answer many other questions you will ask that have nothing to do with ULX
You seem to have a bad habit of ignoring our answers.
Just look at your sv_messageurl thread as an example.
« Last Edit: December 29, 2007, 03:18:42 pm by JamminR »
Offline louis
Re: Can i make Ulx?
« Reply #7 on: December 29, 2007, 05:16:06 pm »
Yes but zak makes it nice and simple you make a whole world out of it......
Thanks Zak
Offline louis
Re: Can i make Ulx?
« Reply #8 on: December 29, 2007, 05:25:08 pm »
so to just clear this post up.
garrysmod/CFG/Server_cfg
"ServerSettings"
"hostname" "My Server's Name!"
"sv_lan" "0"
"maxplayers" "8"
"sbox_allownpcs" "1"
"sbox_maxprops" "100"
"sbox_maxragdolls" "2"
"sbox_maxnpcs" "0"
"sbox_maxballoons" "10"
"sbox_maxeffects" "50"
"sbox_maxdynamite" "5"
"sbox_maxlamps" "5"
"sbox_maxthrusters" "20"
"sbox_maxwheels" "20"
"sbox_godmode" "0"
"sbox_plpldamage" "1"
"sbox_playergod" "0"
"sbox_noclip" "1"
"sbox_maxhoverballs" "20"
"sbox_maxvehicles" "3"
"sbox_maxbuttons" "20"
"sbox_maxsents" "20"
"sbox_maxemitters" "5"
"sbox_maxspawners" "3"
"sbox_maxturrets" "2"
"net_maxfilesize 55"
Offline louis
Re: Can i make Ulx?
« Reply #9 on: December 29, 2007, 05:26:29 pm »
or?
"ServerSettings"
"sv_lan" "0"
"maxplayers" "8"
"sbox_maxnpcs" "0"
"sbox_maxlamps" "5"
"sbox_godmode" "0"
"sbox_noclip" "1"
"net_maxfilesize" "55"
Re: Can i make Ulx?
« Reply #10 on: December 29, 2007, 05:30:59 pm »
server.cfg would be better than server_cfg.txt
I'm not sure why garry has both.
Offline louis
Re: Can i make Ulx?
« Reply #11 on: December 30, 2007, 03:01:21 am »
Thank you, but it would still work in server_cfg? if so which one is correct?
EDIT: it still is not working i have to put it in manually, can someone leave me a detailed walkthrough
« Last Edit: December 30, 2007, 05:13:58 am by louis »
Offline WildWill
  • Global Moderator
    • Beast_Building_Server
Re: Can i make Ulx?
« Reply #12 on: December 30, 2007, 06:42:51 am »
I'm not sure if this is done automatically but in my startup command line I have in  exec server.cfg so each time the server is started that file is executed. Also, forget about the server_cfg, I'm not even really sure why that is there either but it's not the standard way servers are run. Use the server.cfg and add the line "net_maxfilesize" "55"  Also make sure that you are not using the sv_downloadurl in there as the two will conflict.
And just a heads up, you really shouldn't be sending the maps from your server as you are, the sv_downloadurl is a much better way of doing it but you'll need webhosting of some sort for that.
Offline louis
Re: Can i make Ulx?
« Reply #13 on: December 30, 2007, 09:08:04 am »
Just to be super sure is this the location of the file
Server/garrysmod/addons/ulx/cfg/server.cfg
Offline WildWill
  • Global Moderator
Re: Can i make Ulx?
« Reply #14 on: December 30, 2007, 10:01:23 am »
That is correct.
EDIT: For all ye that may come across this post, I did not read the above post correctly. That is the wrong file to modify.
« Last Edit: December 30, 2007, 02:04:59 pm by WildWill »
