Author Topic: !ban stopped woprking  (Read 8168 times)
Offline jnewcombe
« on: December 30, 2007, 06:40:35 am »
Hi
Over the last week or so my !ban command and ulx ban has stopped working , all the other commands work apart from that any suggestions on fixing it?
Jon
Seige
Re: !ban stopped woprking
« Reply #1 on: December 30, 2007, 07:54:20 am »
you have to type this:             !ban blah 5 minutes
But if you're talking about the menu, yeah, that doesn't work anymore.
« Reply #2 on: December 30, 2007, 02:35:51 pm »
Jon, really difficult to tell with what little detail you've provided.
Are you getting any errors at ULib/ULX startup?
What are you typing to ban?
Are you getting errors when you type the ban command?
Can other admins, if you have any, ban?
Are you using our current release, 3.2? Or are you using SVN? If SVN, what revision?
Seige is correct about current release. 3.2 requires ban time and reason (though, minutes is assumed Seige. The way you are banning would make 'minutes' the reason for ban, not anything to do with actual time)
This is a bug we've fixed for next release.
Did you try new addons?
Some addons monitor chat text.
Think back to the time it started happening... what changed on the server?
If other admins can ban, it might be a clientside scripts issue on your side.
Offline jnewcombe
« Reply #3 on: January 01, 2008, 04:43:45 am »
aw ty i wasnt using the right full command , was only using
!ban blah 10
rather than
!ban blah 10 reason
thanks again
« Reply #4 on: January 01, 2008, 10:28:52 am »
You're welcome. And sorry we didn't catch that for the release.
It is fixed for the next version. We hope to have one soon.
Offline jnewcombe
« Reply #5 on: January 02, 2008, 08:41:51 am »
thanks again for quick support and keep up the good work!
Jon
