Author Topic: Unassigned user group  (Read 6413 times)
compuwiz
« on: January 03, 2008, 08:12:49 pm »
I am using sui_scoreboard and UTeam (happened before UTeam was installed too) and it says "Unassigned" for the team and with UTeam the same thing happens and it dosent change my health, color, or movement speed. I have the admins sepcified in the users file in settings and I have ULX admin. Everything worked until I transfered my server over from one host to another and I re-copied over all the ULib, ULX, sui_scoreboard, and UTeam files and it didn't help.
Re: Unassigned user group
« Reply #1 on: January 03, 2008, 08:16:28 pm »
Several key data files are stored in gmod/data/ULib and other locations under data.
If you didn't copy those, that would happen.
You may have to re-edit your Uteam config file. See the release here for how to
Offline compuwiz
« Reply #2 on: January 04, 2008, 12:29:44 pm »
I deleted the ULib folder so it could re-create it and it didn't help, but it was also doing this before I had UTeam as well.
« Last Edit: January 04, 2008, 12:31:15 pm by compuwiz »
Professorlava
« Reply #3 on: January 04, 2008, 12:36:46 pm »
this happened to me to i just re extracted the files... turns out i only extracted one of the files the first time.
Offline compuwiz
« Reply #4 on: January 04, 2008, 01:53:58 pm »
I have all of them, I have already re-extracted everything ULX related.
Offline spbogie
« Reply #5 on: January 05, 2008, 12:59:52 pm »
It will happen before you install UTeam because by default gmod doesn't set any teams. If it's still happening after then you are likely missing, or have a malformed/corrupt UTeam.txt file. Please redownload and extract the default UTeam.txt file to the correct location (read the readme) and see if it works.
