Author Topic: Simple Prop Protection Jail Fix  (Read 6030 times)
« on: January 07, 2008, 02:43:35 pm »
Ok I know many of you have seen this happen. You jail a player and turn around just to see them get out. Well, I've made a fix to this. They would get out by bouncing against the walls making them the owner of the props, then they would either unfreeze all props with "R" or goto S.P.P client and clean up props.
-- Simple Prop Protection
-- By Spacetech
if(SinglePlayer()) then
Msg("==================================================\n")
Msg("Simple Prop Protection by Spacetech has NOT loaded\n")
Msg("   You are in single player    \n")
return
AddCSLuaFile("autorun/client/cl_SPropProtection.lua")
local SPropProtection = {}
SPropProtection["Props"] = {}
function SPropProtection.LoadSettings()
if(!file.Exists("SPP/Config.txt")) then return false end
local File = file.Read("SPP/Config.txt")
SPropProtection["Config"] = util.KeyValuesToTable(File)
return true
function SPropProtection.MakeSettings()
if(file.Exists("SPP/Config.txt")) then return end
SPropProtection["Config"] = {}
SPropProtection["Config"]["toggle"] = 1
SPropProtection["Config"]["admin"] = 1
SPropProtection["Config"]["use"] = 1
SPropProtection["Config"]["edmg"] = 1
SPropProtection["Config"]["pgr"] = 1
SPropProtection["Config"]["awp"] = 1
SPropProtection["Config"]["dpd"] = 1
SPropProtection["Config"]["dae"] = 0
SPropProtection["Config"]["delay"] = 120
file.Write("SPP/Config.txt", util.TableToKeyValues(SPropProtection["Config"]))
--[[ My OWN SAVE AND LOAD SYSTEM :D ]]
if(!SPropProtection.LoadSettings()) then
function SPropProtection.NofityAll(Text)
for k, ply in pairs(player.GetAll()) do
ply:SendLua("GAMEMODE:AddNotify(\""..Text.."\", NOTIFY_GENERIC, 5); surface.PlaySound(\"ambient/water/drip"..math.random(1, 4)..".wav\")")
ply:PrintMessage(HUD_PRINTCONSOLE, Text)
Msg(Text.."\n")
function SPropProtection.Nofity(ply, Text)
function SPropProtection.AdminReload(ply)
if(ply) then
if(ply:IsValid() && ply:IsAdmin()) then
for k, v in pairs(SPropProtection["Config"]) do
ply:ConCommand("SPropProtection_"..k.." "..v.."\n")
for k1, v1 in pairs(player.GetAll()) do
if(v1:IsValid() && v1:IsAdmin()) then
for k2, v2 in pairs(SPropProtection["Config"]) do
v1:ConCommand("SPropProtection_"..k2.." "..v2.."\n")
function SPropProtection.LoadBuddies(ply)
local SaveSteamID = string.Replace(ply:SteamID(), ":", ".")
if(file.Exists("SPP/"..SaveSteamID..".txt")) then
SPropProtection[ply:SteamID()] = util.KeyValuesToTable(file.Read("SPP/"..SaveSteamID..".txt"))
function SPropProtection.PlayerMakePropOwner(ply, ent)
if(ent:GetClass() == "transformer" && ent.spawned && !ent.Part) then
for k, v in pairs(transpiece[ent]) do
v.Part = true
SPropProtection.PlayerMakePropOwner(ply, v)
if(ent:IsPlayer()) then return end
SPropProtection["Props"][ent:EntIndex()] = {ply:UniqueID(), ent}
ent:SetNetworkedString("Owner", ply:Nick())
if(cleanup) then
local Clean = cleanup.Add
function cleanup.Add(Player, Type, Entity)
if(Entity) then
local Check = Player:IsPlayer()
local Valid = Entity:IsValid()
    if(Check and Valid) then
        SPropProtection.PlayerMakePropOwner(Player, Entity)
    Clean(Player, Type, Entity)
local Meta = FindMetaTable("Player")
if(Meta.AddCount) then
local Backup = Meta.AddCount
function Player:AddCount(Type, Entity)
SPropProtection.PlayerMakePropOwner(self, Entity)
Backup(self, Type, Entity)
function SPropProtection.IsBuddy(ply, ent)
local Players = player.GetAll()
if(table.Count(Players) == 1) then return true end
for k,v in pairs(Players) do
if(v:IsValid() && v != ply) then
        if(SPropProtection["Props"][ent:EntIndex()][1] == v:UniqueID()) then
                if(table.HasValue(SPropProtection[v:SteamID()], ply:SteamID())) then
return true
return false
function SPropProtection.PlayerCanTouch(ply, ent)
if(tonumber(SPropProtection["Config"]["toggle"]) == 0) then
return true
if(string.find(ent:GetClass(), "stone_") == 1 || string.find(ent:GetClass(), "rock_") == 1 || string.find(ent:GetClass(), "stargate_") == 1 || string.find(ent:GetClass(), "dhd_") == 1 || ent:GetClass() == "flag" || ent:GetClass() == "item") then
if(!ent:GetNetworkedString("Owner") || ent:GetNetworkedString("Owner") == "") then
ent:SetNetworkedString("Owner", "World")
if(ply:GetActiveWeapon():GetClass() != "weapon_physgun" && ply:GetActiveWeapon():GetClass() != "gmod_tool") then
return true
elseif(!ply:IsAdmin()) then
return false
if(ent:GetNetworkedString("Owner") == "World") then
if(ply:IsAdmin() && tonumber(SPropProtection["Config"]["awp"]) == 1 && tonumber(SPropProtection["Config"]["admin"]) == 1) then
return true
return false
elseif(ply:IsAdmin() && tonumber(SPropProtection["Config"]["admin"]) == 1) then
return true
if(SPropProtection["Props"][ent:EntIndex()] != nil) then
if(SPropProtection["Props"][ent:EntIndex()][1] == ply:UniqueID() || SPropProtection.IsBuddy(ply, ent)) then
return true
return false
for k, v in pairs(g_SBoxObjects) do
for b, j in pairs(v) do
for _, e in pairs(j) do
if(k == ply:UniqueID() && e == ent) then
SPropProtection.Nofity(ply, "You now own this prop")
return true
for k, v in pairs(GAMEMODE.CameraList) do
if(j == ent) then
return true
return false
function SPropProtection.DRemove(UniqueID, PlayerName)
for k, v in pairs(SPropProtection["Props"]) do
if(v[1] == UniqueID && v[2]:IsValid()) then
v[2]:Remove()
SPropProtection["Props"][k] = nil
SPropProtection.NofityAll(tostring(PlayerName).."'s props have been cleaned up")
function SPropProtection.PlayerInitialSpawn(ply)
SPropProtection[ply:SteamID()] = {}
local TimerName = "SPropProtection.DRemove: "..ply:UniqueID()
if(timer.IsTimer(TimerName)) then
timer.Remove(TimerName)
hook.Add("PlayerInitialSpawn", "SPropProtection.PlayerInitialSpawn", SPropProtection.PlayerInitialSpawn)
function SPropProtection.Disconnect(ply)
if(tonumber(SPropProtection["Config"]["dpd"]) == 1) then
if(ply:IsAdmin() && tonumber(SPropProtection["Config"]["dae"]) == 0) then return end
timer.Create("SPropProtection.DRemove: "..ply:UniqueID(), tonumber(SPropProtection["Config"]["delay"]), 1, SPropProtection.DRemove, ply:UniqueID(), ply:Nick())
hook.Add("PlayerDisconnected", "SPropProtection.Disconnect", SPropProtection.Disconnect)
function SPropProtection.PhysGravGunPickup(ply, ent)
if(!ent:IsValid()) then return end
if(ent:IsPlayer() && ply:IsAdmin() && tonumber(SPropProtection["Config"]["admin"]) == 1) then return end
if(!ent:IsValid() || !SPropProtection.PlayerCanTouch(ply, ent)) then
return false
hook.Add("GravGunPunt", "SPropProtection.GravGunPunt", SPropProtection.PhysGravGunPickup)
hook.Add("GravGunPickupAllowed", "SPropProtection.GravGunPickupAllowed", SPropProtection.PhysGravGunPickup)
hook.Add("PhysgunPickup", "SPropProtection.PhysgunPickup", SPropProtection.PhysGravGunPickup)
function SPropProtection.CanTool(ply, tr, toolgun)
if(tr.HitWorld) then return end
ent = tr.Entity
if(!ent:IsValid() || ent:IsPlayer()) then return false end
if(!SPropProtection.PlayerCanTouch(ply, ent)) then
return false
elseif(toolgun == "nail") then
local Trace = {}
Trace.start = tr.HitPos
Trace.endpos = tr.HitPos + (ply:GetAimVector() * 16.0)
Trace.filter = {ply, tr.Entity}
local tr2 = util.TraceLine(Trace)
if(tr2.Hit && !tr2.Entity:IsPlayer()) then
if(!SPropProtection.PlayerCanTouch(ply, tr2.Entity)) then
return false
hook.Add("CanTool", "SPropProtection.CanTool", SPropProtection.CanTool)
function SPropProtection.EntityTakeDamage(ent, inflictor, attacker, amount)
if(tonumber(SPropProtection["Config"]["edmg"]) == 0) then return end
    if(ent:IsPlayer() || !attacker:IsPlayer()) then return end
if(!SPropProtection.PlayerCanTouch(attacker, ent)) then
local Total = ent:Health() + amount
if(ent:GetMaxHealth() > Total) then
ent:SetMaxHealth(Total)
ent:SetHealth(Total)
hook.Add("EntityTakeDamage", "SPropProtection.EntityTakeDamage", SPropProtection.EntityTakeDamage)
function SPropProtection.PlayerUse(ply, ent)
if(ent:IsValid() && tonumber(SPropProtection["Config"]["use"]) == 1) then
if(!SPropProtection.PlayerCanTouch(ply, ent) && ent:GetNetworkedString("Owner") != "World") then
return false
hook.Add("PlayerUse", "SPropProtection.PlayerUse", SPropProtection.PlayerUse)
function SPropProtection.OnPhysgunReload(weapon, ply)
if(tonumber(SPropProtection["Config"]["pgr"]) == 0) then return end
local tr = util.TraceLine(util.GetPlayerTrace(ply))
if(!tr.HitNonWorld || !tr.Entity:IsValid() || tr.Entity:IsPlayer()) then return end
if(!SPropProtection.PlayerCanTouch(ply, tr.Entity)) then
return false
hook.Add("OnPhysgunReload", "SPropProtection.OnPhysgunReload", SPropProtection.OnPhysgunReload)
function SPropProtection.EntityRemoved(ent)
SPropProtection["Props"][ent:EntIndex()] = nil
hook.Add("EntityRemoved", "SPropProtection.EntityRemoved", SPropProtection.EntityRemoved)
function SPropProtection.PlayerSpawnedSENT(ply, ent)
hook.Add("PlayerSpawnedSENT", "SPropProtection.PlayerSpawnedSENT", SPropProtection.PlayerSpawnedSENT)
function SPropProtection.PlayerSpawnedVehicle(ply, ent)
hook.Add("PlayerSpawnedVehicle", "SPropProtection.PlayerSpawnedVehicle", SPropProtection.PlayerSpawnedVehicle)
function SPropProtection.CleanupOwnerlessProps(ply, cmd, args)
if(!ply:IsAdmin()) then return end
for k, v in pairs(ents.FindByClass("*")) do
if((!v:GetNetworkedString("Owner") || v:GetNetworkedString("Owner") == "") && v:GetClass() != "worldspawn" && v:IsValid()) then
v:Remove()
SPropProtection.NofityAll("Ownerless props have been cleaned up")
--concommand.Add("SPropProtection_CleanupOwnerlessProps", SPropProtection.CleanupOwnerlessProps)
function SPropProtection.CleanupDisconnectedProps(ply, cmd, args)
for k1, v1 in pairs(SPropProtection["Props"]) do
local FoundUID = false
for k2, v2 in pairs(player.GetAll()) do
if(v1[1] == v2:UniqueID()) then
FoundUID = true
if(FoundUID == false && v1[2]:IsValid()) then
v1[2]:Remove()
SPropProtection["Props"][k1] = nil
SPropProtection.NofityAll("Disconnected players props have been cleaned up")
concommand.Add("SPropProtection_CleanupDisconnectedProps", SPropProtection.CleanupDisconnectedProps)
function SPropProtection.CleanupProps(ply, cmd, args)
if(!args[1] || args[1] == "") then
if(v[1] == ply:UniqueID()) then
if(v[2]:IsValid()) then
v[2]:Remove()
SPropProtection.Nofity(ply, "Your props have been cleaned up")
elseif(ply:IsAdmin()) then
local FoundPlayer = false
if(args[1] == v1:Nick()) then
for k2, v2 in pairs(SPropProtection["Props"]) do
if(v2[1] == v1:UniqueID()) then
if(v2[2]:IsValid()) then
v2[2]:Remove()
SPropProtection["Props"][k2] = nil
SPropProtection.NofityAll(v1:Nick().."'s props have been cleaned up")
concommand.Add("SPropProtection_CleanupProps", SPropProtection.CleanupProps)
function SPropProtection.ApplyBuddySettings(ply, cmd, args)
if(table.Count(Players) > 1) then
for k, v in pairs(Players) do
local NewNick = string.Replace(v:Nick(), " ", "_")
local PlayersSteamID = v:SteamID()
if(tonumber(ply:GetInfo("SPropProtection_BuddyUp_"..NewNick)) == 1) then
if(!table.HasValue(SPropProtection[ply:SteamID()], PlayersSteamID)) then
table.insert(SPropProtection[ply:SteamID()], PlayersSteamID)
if(table.HasValue(SPropProtection[ply:SteamID()], PlayersSteamID)) then
for k2, v2 in pairs(SPropProtection[ply:SteamID()]) do
if(v2 == PlayersSteamID) then
table.remove(SPropProtection[ply:SteamID()], k2)
if(table.Count(SPropProtection[ply:SteamID()]) > 0) then
file.Write("SPP/"..SaveSteamID..".txt", util.TableToKeyValues(SPropProtection[ply:SteamID()]))
elseif(file.Exists("SPP/"..SaveSteamID..".txt")) then
file.Delete("SPP/"..SaveSteamID..".txt")
SPropProtection.Nofity(ply, "Your buddies have been updated")
concommand.Add("SPropProtection_ApplyBuddySettings", SPropProtection.ApplyBuddySettings)
function SPropProtection.ClearBuddies(ply, cmd, args)
file.Delete("SPP/"..string.Replace(ply:SteamID(), ":", ".")..".txt")
ply:ConCommand("SPropProtection_BuddyUp_"..NewNick.." 0\n")
SPropProtection.Nofity(ply, "Your buddies have been cleared")
concommand.Add("SPropProtection_ClearBuddies", SPropProtection.ClearBuddies)
function SPropProtection.ApplySettings(ply, cmd, args)
SPropProtection["Config"]["toggle"] = tonumber(ply:GetInfo("SPropProtection_toggle") || 1)
SPropProtection["Config"]["admin"] = tonumber(ply:GetInfo("SPropProtection_admin") || 1)
SPropProtection["Config"]["use"] = tonumber(ply:GetInfo("SPropProtection_use") || 1)
SPropProtection["Config"]["edmg"] = tonumber(ply:GetInfo("SPropProtection_edmg") || 1)
SPropProtection["Config"]["pgr"] = tonumber(ply:GetInfo("SPropProtection_pgr") || 1)
SPropProtection["Config"]["awp"] = tonumber(ply:GetInfo("SPropProtection_awp") || 1)
SPropProtection["Config"]["dpd"] = tonumber(ply:GetInfo("SPropProtection_dpd") || 1)
SPropProtection["Config"]["dae"] = tonumber(ply:GetInfo("SPropProtection_dae") || 1)
SPropProtection["Config"]["delay"] = tonumber(ply:GetInfo("SPropProtection_delay") || 120)
timer.Simple(2, SPropProtection.AdminReload())
SPropProtection.Nofity(ply, "Admin settings have been updated")
concommand.Add("SPropProtection_ApplyAdminSettings", SPropProtection.ApplySettings)
function PlayerCanUseConCommand(ply)
if(ply && !ply:IsValid()) then
return true
return true
return false
function SPropProtection.ReloadSettings(ply, cmd, args)
local Check = false
Check = true
Check = true
if(Check == false) then return end
local Text = ""
if(SPropProtection.LoadSettings()) then
Text = "Admin settings has been reloaded"
Text = "Admin settings has not been found...created one..."
if(ply:IsValid()) then
Msg(Text.."\n")
concommand.Add("SPropProtection_ReloadSettings", SPropProtection.ReloadSettings)
function SPropProtection.WorldOwner()
local WorldEnts = 0
v:SetNetworkedString("Owner", "World")
WorldEnts = WorldEnts + 1
Msg("================================================\n")
Msg("Simple Prop Protection: "..tostring(WorldEnts).." props belong to world\n")
timer.Simple(10, SPropProtection.WorldOwner)
Msg("==============================================\n")
Msg("Simple Prop Protection by Spacetech has loaded\n")
that is the code for the lua/autorun/server/SPropProtection.lua, and i'm also attaching the file if you choose to do it that way. PLZ comment if you find any bugs!
