Author Topic: Simple Prop Protection won't cleanup disconnected players props  (Read 5816 times)
Offline compuwiz
« on: January 13, 2008, 09:41:35 am »
I have tried changing all the settings but SPP won't clean up disconnected players props automatically. I havent gotten a response on FacePunch so I thought I would try asking here.
Re: Simple Prop Protection won't cleanup disconnected players props
« Reply #1 on: January 13, 2008, 09:42:50 am »
You probably have another script that's moronically blocking the disconnect hook. ECS is the most likely. If you don't have ECS, try removing all your addons but SPP and see if the problem persists; otherwise add the addons back one by one to see which it is.
Offline compuwiz
« Reply #2 on: January 14, 2008, 05:02:02 pm »
I removed ecs, now you can only grab props with the phys gun, not rag dolls, or things like hoverballs, or life support stuff. I will keep working on it and I will post here if I find a solution, until then post your ideas.
If you want to see what I mean: 208.100.34.21:27017
« Last Edit: January 15, 2008, 06:11:16 pm by compuwiz »
Offline hatred
« Reply #3 on: February 22, 2008, 08:50:30 am »
I have a modified version of ECS that works with no hooking issues and uses ULX/ULib for access control. So you will need to place an "ecs" flag on the users/groups you want to have ECS access.
If you want it, let me know.
