Author Topic: GMOD Update Released  (Read 7138 times)
Offline Avien
« on: January 15, 2008, 06:06:39 pm »
[-]January 15, 2008 - Garry's Mod Update Released
Updates to Garry's Mod have been released. The updates will be applied automatically when your Steam client is restarted. The specific changes include:
Garry's Mod
Switched to use the Orange Box Engine
Added support for Team Fortress 2, Half-Life 2: Episode Two and Portal
Updated Spawnmenu
Updated gm_construct
New loading screen
New 'Start Game' menus
Lamps now cast shadows (if supported by hardware)
Too bad it breaks dedicated servers.  I would let you know if ULX worked, but my dedicated server wants to run Day of Defeat now after the update.
Offline spbogie
Re: GMOD Update Released
« Reply #1 on: January 15, 2008, 06:51:25 pm »
The current version of ULX will not work (or at least not the way it should), but we have been testing with the beta on the side and have a version which was working last we tested. Once we get a chance to make sure it's working in the release of the update we'll get it out.
Offline Avien
« Reply #2 on: January 15, 2008, 08:06:11 pm »
Well the entire game is broken now.  Servers don't work, or at least show up on the server list, random crashes, etc...
Offline Pugnacious
« Reply #3 on: January 15, 2008, 09:58:46 pm »
I may have posted in the wrong section, but i posted a topic on how to get dedicated servers working again in the general help and support section.
Offline Banyon
    • Kill 'a' Byte
« Reply #4 on: January 15, 2008, 10:50:29 pm »
Considering I don't see a single dedicated server running, or any multiple servers for that matter, this might be a question best left to valve... there is a difference between getting an admin mod working on a server, and getting the actual server code to fire up.
FreeFry
« Reply #5 on: January 16, 2008, 01:46:18 am »
You need to use the TeamFortress 2 source server binaries to make the servers start. (use the steam dedicated server, and download the binaries there, then copy them over to your srcds directory(overwriting any files there), then it should work).
Atleast for now that's the only fix I've come across.
