Author Topic: A note to the brave  (Read 28869 times)
A note to the brave
« on: January 15, 2008, 09:02:24 pm »
If you were brave enough to update your servers, and to find them broken to bits, we have a smidgen of good news for you. The ULX and ULib SVN trunks have been updated to "work" with the new updates. We make no guarantees that everything will work, but in my quick checks most everything seemed intact. Thanks to spbogie for quickly getting us up to speed on this!
Re: A note to the brave
« Reply #1 on: January 15, 2008, 09:29:41 pm »
My server list is empty. I understand a FEW may not be up to date, but ALL?
Well, it's nice to know ULX and ULib are ready for when Gmod is.
Offline Pugnacious
« Reply #2 on: January 15, 2008, 09:55:46 pm »
There's a fix for the server itself to make it run.  I'm making a post about it in what i hope is the correct place.  Also, the updated svn runs, but none of the ulx commands work in my server yet.
Offline p1cwh0r3
« Reply #3 on: January 16, 2008, 04:31:54 am »
Same issue here. ULX not running.
I can't make sense of any LUA errors as there are mostly none either in console or in game. If there is it's 1/2 a message or "unexpected variable".
I wish I could help with more but I'll see what I can do.
« Reply #4 on: January 16, 2008, 07:09:35 am »
Show us the errors. You are using SVN, correct?
Offline LoC
« Reply #5 on: January 16, 2008, 02:33:48 pm »
My ded. server says there is a error. Before rev. 124 it wasn't there.
ULib/server/hook.lua:141 attempt to call global 'type' <a nil value>
« Reply #6 on: January 16, 2008, 02:44:01 pm »
Fixed. Thanks!
Ham N Jelly
« Reply #7 on: January 16, 2008, 05:20:36 pm »
Thank you for fixing it so it will work, but now the menu isnt, the error code thing is:
Ham N Jelly
« Reply #8 on: January 16, 2008, 05:31:43 pm »
ULib/shared/sh_ucl.lua:38: attempt to index field '?' (a nil value)
sorry about 2 post, didnt mean to! and also, the maul dosnt kill you any more, you just stand there.
Offline p1cwh0r3
« Reply #10 on: January 17, 2008, 04:13:32 am »
Yes, using SVN. Im doing a fresh install tonight and I'm goin to copy down every error I encounter both Client and console.
Edit: I am running SVN 125 as well.
This server is running ULib version 2.10.
Redownloading all lightmaps
Water Overlay Material '0' wasn't found.
ULX version 3.21 (BETA) SVN revision 125 loaded.
Command: ulx clientmenu
Client side Error: ULib/shared/sh_ucl.lua:38: attempt to index field '?' (a nil value)
Console Error: (no error)
Comment: Players can be seen on the left but all client commands are missing.
Command: Clicking on any command in the Admin menu
Client side Error: ulx/modules/cl/adminmenu.lua:45: bad argument #1 to 'SetText' (string expected, got nil)
Comments: Slider values work fine, no errors there. Error is when Allow NPC's, PVP damage, Global Noclip and Global Godmode are clicked on.
Command: ulx maul
Client side Error: (No Error)
Console Error: (After player suicides when Maul completes) Entity 174 (class 'npc_headcrab_fast') reported ENTITY_CHANGE_NONE but 'm_hEffectEntity' changed.
Comments: Maul starts but no player damage caused. After 30 seconds or so player health drops to 1, then a further 30 seconds after taht maul finishes and player suicides. See attached demo.
Command: ulx menu
Console Error: (No Error)
Comments:
Command: ulx cloak
Comments: When cloaked with value 255 then uncloaked the weapons/tools are not visible to anyone else but in First person view weapons are visible.
Command: ulx hp (Minor old bug)
Comments: Minor issue but client crashable. When a player has HP set to 99,999 and has a GM entity ball (causing player to bypass previous 100,000 crash fix)
Will be edited as more arise
« Last Edit: January 17, 2008, 07:58:51 am by p1cwh0r3 »
« Reply #11 on: January 17, 2008, 06:59:02 am »
the menu commands rely on clientside scripting.. Megiddo has already said that this was broken at this time... They already know about the client menu and Menu commands.
As for maul.. and cloak, im not sure what would be causing those.. unless of course they were more client side.
Offline p1cwh0r3
« Reply #12 on: January 17, 2008, 07:34:42 am »
Yea I read the additional post about the conversation with Garry. I've just got heaps of time on my hands.
Offline Toxic
« Reply #13 on: January 21, 2008, 09:44:09 am »
my ulx wont work and i downloaded it
« Reply #14 on: January 21, 2008, 09:51:31 am »
Command: ulx maul
Command: ulx menu
Comments:
Command: ulx cloak
Oops, forgot about your post here, sorry. The menus and maul should be fixed now, the thing with cloak is a necessary bug, and trying to do anything more about ulx hp would be crazy... are there admins taking advantage of this?
