Author Topic: Non-Running Dedicated Server Fix  (Read 5039 times)
Offline Pugnacious
« on: January 15, 2008, 09:57:41 pm »
I hope this is the correct place to put this, but the dedicated server update did not come with the correct ep2 files.  Simply have your server host copy these files to your gameserver after the update:
orangebox/bin/*.*
orangebox/platform/*.*
orangebox/srcds.exe
These files can be found in the TF2 dedicated server files.  Also, it's recommended that you do a full install of the new update, and not simply update your existing server.
Re: Non-Running Dedicated Server Fix
« Reply #1 on: January 16, 2008, 03:18:45 pm »
Pug, you left out one big step you (as the host) or your host would need to do first.
Run the hldsupdatetool and install the Team Fortress 2 server files.
hldsupdatetool -command install -game tf -dir <where_it_should_go>
