Author Topic: Any other bugs in the new GMod update with ULX?  (Read 14693 times)
« on: January 17, 2008, 03:41:01 pm »
Except for ulx maul and some ugly lines in the menus, ULX should now be fully functional in the new GMod. Let us know if you have any new bugs!
Offline johnlukeg
Re: Any other bugs in the new GMod update with ULX?
« Reply #1 on: January 17, 2008, 04:48:59 pm »
Are you referring to a new version of ULX?  I downloaded mine recently before the update and simply doesn't work now as you can imagine.  I've never used SVN, and can't find where to get yours from the site...  Well at least Uteam is still working on the server...
« Reply #2 on: January 17, 2008, 05:00:50 pm »
Not a new release, but our beta work in SVN.
You can't? You didn't look hard. It's a Sticky. At the top of the SVN forum. It's also on www.ulyssesmod.net a few news articles down from the top.
SVN, both our release, and the actual use/application itself, isn't for the faint of heart. If you don't have a technical aptitude, you might want to wait for our next release.
Offline johnlukeg
« Reply #3 on: January 17, 2008, 05:21:09 pm »
Technical Aptitude eh?  I should probably wait for the next release.  On the other hand I have no idea when that will be and I need an admin mod.  Don't worry, if I doom my server to death, I won't whine to you guys...
« Reply #4 on: January 19, 2008, 11:44:02 am »
Anyone notice any bugs we haven't covered?
Offline cube334
« Reply #5 on: January 20, 2008, 03:44:20 am »
ulx maul when you die and they kill you they disapear
then when u press mouse1 you keep dieing and you cant never respawn unless you reconnect
« Reply #6 on: January 20, 2008, 04:07:22 am »
Working as intended....
« Reply #7 on: January 21, 2008, 03:49:36 pm »
!ragdoll - Forgot to look in console to see if an error occurs.
When using the command on self, you no longer have movement above your body. You're stuck at eye level.
I tried this on a multiplayer server, same issue.
@@@ (csay?) didn't work.
EDIT - From Today's GMOD update - mp_forcecamera now defaults to 0 (in line with previous versions)
Might fix ragdoll. We'll see shortly (when I get a chance to test it)
« Last Edit: January 21, 2008, 05:44:06 pm by JamminR »
« Reply #8 on: January 23, 2008, 07:42:13 pm »
ulx teleport when used on another player will cause them to appear inside of you instead of where you are looking. Bug?
Offline atomicspark
« Reply #9 on: January 24, 2008, 08:03:04 pm »
Yes
Offline Avien
« Reply #10 on: January 24, 2008, 09:55:02 pm »
I was going to report that as well.  After that my ulx menu broke.
« Reply #11 on: January 25, 2008, 01:39:35 pm »
Ragdoll works fine, csay worked fine for me too.
Fixed.
Any other bugs? Let us know NOW!
« Reply #12 on: January 26, 2008, 10:36:53 am »
ulx usermangementhelp returns no info if it's already been run once. This was while in singleplayer after a game restart. I've not tested further.
I discovered this while trying to grab some info from it for another forum.
« Reply #13 on: January 26, 2008, 11:04:45 am »
Works for me.
Offline Avien
« Reply #14 on: January 26, 2008, 02:24:49 pm »
ERROR: Hook 'sendMapAutoComplete' Failed: ulx\modules/util.lua:69: bad argument #1 to 'ipairs' (table expected, got nil)
Removing Hook 'sendMapAutoComplete'
SVN Revision 140, singleplayer game, gm_construct.
