Author Topic: ULX command won't show in console..HELP  (Read 8194 times)
Offline DemonicWinna
« on: January 19, 2008, 12:26:16 am »
I installed them (both ulib and ULX) and it doesn't whos ulx command in the console and when i type something like "ulx adduser" it says thats a unknown command!!!!!
Re: ULX command won't show in console..HELP
« Reply #1 on: January 19, 2008, 01:12:08 am »
If you are using the current SVN, then this might be a problem, however if you are not using the SVN version, you are doing it wrong.
It says it all over the place that ULX is broken in the new GMod update.. it's fixed in SVN, but TeamU is waiting to make it an actual release until they clean it up a bit more. The SVN is currently public however.. so get that if you haven't already. =)
« Reply #2 on: January 19, 2008, 02:05:00 am »
I know about SVN.I un-installed everything and added the addons and now it works!
Sorry to make this post:(
Also, I read somewhere that some commands will only work via console, is their a patch planned to fix this?Or is this done from garry's patch?
« Reply #3 on: January 19, 2008, 08:56:24 am »
There is no such problem that we know of Demonic.
illizit
« Reply #4 on: January 20, 2008, 11:32:44 am »
Hey guys, I downloaded the SVN version and placed it on the server however none of the commands work. It looks like its not even loading ULX.
I'm runing a dedicated server and I now have the orangebox folder after I did a complete reinstall of the server, is this because of the new update? Anyways, I placed the svn inside orangebox/garrysmod/addons/ulx, this is correct right?
Any help is appreciated, thanks!
« Reply #5 on: January 20, 2008, 11:36:42 am »
You need ULib too.
illizit
« Reply #6 on: January 20, 2008, 12:16:07 pm »
Yes, I do have ulib. This is the folder structure:
orangebox/garrysmod/addons/ulx/lua/ULib
orangebox/garrysmod/addons/ulx/lua/ULib/modules/ulx_init.lua
orangebox/garrysmod/addons/ulx/lua/ulx
.. etc.
I restarted the server and still no go.
« Reply #7 on: January 20, 2008, 12:23:03 pm »
Any errors in console?
Offline illizit
    • TheGamersJunction.com - The Next Level of Gaming
« Reply #8 on: January 20, 2008, 12:26:20 pm »
well, I get quite a few. lol
Here is some:
No particles in manifest. Search path cstrike (I know it has nothing to do with this, but do you know how to fix this error?)
Then I have:
Error Module 'ulib' no found!
« Reply #9 on: January 20, 2008, 12:34:03 pm »
Anything else?
Offline illizit
« Reply #10 on: January 20, 2008, 12:40:45 pm »
Sure:
ULib/init.lua:6: attempt to call field 'pluginLoaded' (a nil value)
SERVER: Registering gamemod 'sandbox' derived from 'base'
ScriptEnforce: gamemodes/sandbox/clientscripts.txt wasn't found. this gamemod is unprotected.
Thats pretty much it. Thanks for the help
Offline illizit
« Reply #11 on: January 20, 2008, 12:50:54 pm »
Sorry to have wasited your time, I reploaded ulib and now it works. I guess I was missing a file or something. I can confirm though that the SVN version works fairly well. Thanks for the help!
« Reply #12 on: January 20, 2008, 01:48:11 pm »
Oh, no worries.
Megiddo is working on fixing that right now.  :D ;D :P
/index.php/topic,3155.0.html
