Author Topic: Adding immunity  (Read 4760 times)
Offline Avien
Adding immunity
« on: January 19, 2008, 02:14:19 pm »
I have got the server all setup and running fine with ulx and ulib.  I have added all the admins, etc..., to the settings/users.txt file.  My question is, how do i go about adding immunity to this file?
Here is my example:
"Users"
// This is your users file
// You can use this file to add people as admins on your server
// Add them to the relevant section
// If you're a Lua coder you can add your own sections and use them
// in your script by doing pl:IsUserGroup( "admin" ) etc
"owner"
"xxxxxxxxxx" "STEAM_0:0:xxxxxx"
"itmanager"
"xxxxxxxxxxx" "STEAM_0:0:xxxxxxxxxx" "immunity"
"superadmin"
"admin"
"xxxxxxxx" "STEAM_0:0:xxxxxx"
"xxxxxxxx" "STEAM_0:1:xxxxxxxxx"
"xxxxxxxx" "STEAM_0:0:xxxxxxx"
"xxxxxxxx" "STEAM_0:1:xxxxxxxxxxx"
"operator"
//"xxxxxxx" "STEAM_0:0:xxxxxxx"
I would rather do it this way then simply using the console, or whatnot.
Re: Adding immunity
« Reply #1 on: January 19, 2008, 02:15:40 pm »
You can't add immunity from settings/users.txt. You should really use the console, it's the easiest and the most effective. :)
If you must do it by hand, add "immunity" to the user's or group's allow table.
Offline Avien
Re: Adding immunity
« Reply #2 on: January 19, 2008, 02:33:29 pm »
I know the console is easier, i just like the layout better.
I will give what you said a try.
Thanks
