Author Topic: error with the new ULib SVN revision.  (Read 5251 times)
Killers
« on: January 21, 2008, 02:32:24 pm »
I am getting the following error when i spawn on my dedicated server after putting the new revision onto it : "ULib/client/cl_until.lua:70@ Tried to use a NULL entity!
Re: error with the new ULib SVN revision.
« Reply #1 on: January 21, 2008, 02:51:53 pm »
Anyone else having this problem?
Offline Avien
« Reply #2 on: January 21, 2008, 04:09:31 pm »
I am not getting it.  Might be that he is using a downloadurl and didn't copy over his .dua(s)?
Killers
« Reply #3 on: January 23, 2008, 12:45:12 pm »
No i am not using a sv_downloadurl ( yet anyways )
Offline spbogie
« Reply #4 on: January 23, 2008, 01:55:10 pm »
There is no cl_until.lua file in ULib. If you meant cl_util.lua then line 70 is "end" which is not touching an Entity at all. Please check the error you gave again, and this time actually copy the full thing from console rather than trying to retype it.
