Author Topic: some Lua help regarding ulib/ulx  (Read 4211 times)
Lil Jon
« on: January 31, 2008, 09:28:29 am »
hey guys i had ULX admin mod working for quite some time but this new update came out and mine seems messed up, ive reinstalled all addons and delteted lots,  im running it on a lan server using hamchi (not sure if you know of it, lets you lan throught internet) but i get all sorts of error  example  when i type  !menu i get    "  ulx/modules/cl/mainmenu.lua:10: attempt to index field 'ucl' (a nil value)  "     !adminmenu i get "  ulx/modules/cl/adminmenu.lua:56: attempt to call field 'isSandbox' (a nil value)  "  the list goes on, i got lots of errors on startup as well,    any help would be greatly appreciated as ive read thousands of posts im stumped i reali dont know what to do, so if someone could please help me that would be great :)
thanks
Lj
Re: some Lua help regarding ulib/ulx
« Reply #1 on: January 31, 2008, 11:34:40 am »
1. make sure you have the newest version of ULX.. I BELIEVE that Megiddo has made the working version into the release rather than the SVn now.. so that should make that easy..
2. Make sure you have not just ULX.. but ULib as well.. they are seperate addons but ULX REQUIRES ULib to work...
3. Make sure you actually own GarrysMod... Im not accusing you so dont freak out.. just something I thought when you said Hamichi.
If all 3 of these check out, try running ULX on a clean GMod.. what I mean by that is put all of the addons you've downloaded other than ULX and ULib into another folder so GMod doesnt load them. It is possible that something you have conflicts with ULX.
Lil Jon
« Reply #2 on: February 02, 2008, 12:43:06 pm »
still nothing and yes im not a nublet =P i have gmod,  done a full wipe of addons n reinstaled,   still get same errors  nil value cant find files etc   help! lol
« Reply #3 on: February 02, 2008, 01:00:35 pm »
Clear out your data directory
